1957 john deere 420 fluid type
tgordon12
PostPosted: Mon Apr 04, 2016 6:41 pm    Post subject: 1957 john deere 420 fluid type Reply to specific post Reply with quote
i just purchased a john deere 420 i wondered what fluids it took as far as transmission/ differential. I have ordered a service manual for it but wondered if anyone has used anything in particular they have had good luck with. tractor will need some work but i want to start here and get all the fluids changed. thanks!
M-MAN
PostPosted: Tue Apr 05, 2016 5:47 am    Post subject: Re: 1957 john deere 420 fluid type Reply to specific post Reply with quote
GL 1 140wt. 60wt motor oil would be better if you can find it in your area. Steering box uses the same oil. Use 20wt or 30wt Non Detergent oil in the TOM.
If I'm not mistaken when you get the manual you will find Deere recommended 85/90 wt GL 1 in the tranny and finals when they were new. 140wt in the steering box and 10wt Non Detergent in the TOM. It's been a long time since it was new.
DO NOT FLUSH unless you are planning on completely rebuilding! You will open Pandora's box.
tgordon12
PostPosted: Tue Apr 05, 2016 10:21 am    Post subject: Re: 1957 john deere 420 fluid type Reply to specific post Reply with quote
thank you sir. im a little slow what is the TOM unit? i was under the impression it was all one big cavity transmission, rear end, hydraulics. i have never had a 420 apart, i rebuilt the transmission on an old B i had. I also have a 720 gas but never had that apart either..
thanks for the info!
tgordon12
PostPosted: Tue Apr 05, 2016 1:28 pm    Post subject: Re: 1957 john deere 420 fluid type Reply to specific post Reply with quote
data:image/jpeg;base64,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
M-MAN
PostPosted: Tue Apr 05, 2016 8:35 pm    Post subject: Re: 1957 john deere 420 fluid type Reply to specific post Reply with quote
Touch O Matic. It's just a Deere term for the hydraulic system. The lift assembly bolts to the top. There's a drain plug in the rear under the seat and a petcock up above it to let you know when it's full. Each final drive has it's own drain plug and fill hole as well as the tranny.
