Author |
Message |
newhaven Regular
Posted: Fri Apr 22, 2016 4:22 am Post subject: SUPER C OIL CHANGE |
What type of oil 30w non detergent ?? or detergent |
Back to top |
jsfarmall Regular
Posted: Fri Apr 22, 2016 5:11 am Post subject: Re: SUPER C OIL CHANGE |
Don't have a super c but in my cub, H, and
Super M. Use rotella 15 40 detergent. I
make sure I use 30w non detergent in the
air filter though. Reason being is I have
been told the non detergent oil let's the
dirt settle to the bottom of the cup where
a detergent oil holds the dirt n dust in
suspension. |
Back to top |
kevinj54 Tractor Expert
Posted: Fri Apr 22, 2016 5:20 am Post subject: Re: SUPER C OIL CHANGE |
CVPost-jsfarmall wrote: | (quoted from post at 09:11:50 04/22/16) Don't have a super c but in my cub, H, and
suspension. |
Not sure about that one......I use the rotella-t in the cleaner cup.
The oil is always clean with the dirt on the bottom. |
Back to top |
DanMD Regular
Posted: Fri Apr 22, 2016 5:23 am Post subject: Re: SUPER C OIL CHANGE |
CVPost-jsfarmall wrote: | (quoted from post at 14:11:50 04/22/16) Don't have a super c but in my cub, H, and
suspension. |
This is the same thing my local IH service manager told me about the air cleaners.
Dan |
Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 36291 Location: St. Cloud, MN
Posted: Fri Apr 22, 2016 5:31 am Post subject: Re: SUPER C OIL CHANGE |
Using non-detergent oil is not recommended. The two main reasons that today's engines run 3 times as long as in the 50s. 15-30 Quality oil is recommended. Jim |
Back to top |
riverbend Tractor Expert
Joined: 13 Aug 2003 Posts: 2046 Location: Delano, Minnesota
Posted: Fri Apr 22, 2016 4:04 pm Post subject: Re: SUPER C OIL CHANGE |
You can use any oil you like, but you may need to add a little zinc additive or use diesel oil (Rotella
or other) to protect the cam and lifters. If you do use non-detergent oil you should remove the oil pan
and clean out the crud that settles out. I find it much easier to use a good diesel oil.
Greg |
Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 16473 Location: Delta,colorado
Posted: Fri Apr 22, 2016 5:31 pm Post subject: Re: SUPER C OIL CHANGE |
15/40 fleet diesel.All year around. the same as I run in my 10 running tractors,2 combines,2
pickups,car,motorcycles,ATVs,lawnmowers...... one oil for all. simple that way. |
Back to top |
jsfarmall Regular
Posted: Mon Apr 25, 2016 3:00 am Post subject: Re: SUPER C OIL CHANGE |
Oh ok, I never tried it, just what I have
heard so that's what I always done. Would
make things simpler for sure. |
Back to top |
