1955 ford 650 hex shaft from distributor to oil pump
vharris4
PostPosted: Sun May 08, 2016 12:12 am    Post subject: 1955 ford 650 hex shaft from distributor to oil pump Reply to specific post Reply with quote
I was trying to static time a 650 like a jubilee and pulled the hex shaft that drives the oil pump up with the distributor shaft. Is this shaft fixed in the oil pump with a set screw? I got it to stick in the distributor shaft then seat with the rotor aligned right. I got the tractor started and the pressure gauge is reading almost max. How do I know if the shaft fell in correctly? What problems have I created. I shut it down, afraid it might seize the engine, or do other damage. How do I fix it?
showcrop
PostPosted: Sun May 08, 2016 3:20 am    Post subject: Re: 1955 ford 650 hex shaft from distributor to oil pump Reply to specific post Reply with quote
No set screw. It just drops in. The gauge is probably your problem.
vharris4
PostPosted: Sun May 08, 2016 7:49 am    Post subject: Re: 1955 ford 650 hex shaft from distributor to oil pump Reply to specific post Reply with quote
Whew! Thank you, for that! So, if it fits back right, it's probably correct? If its not the gauge then am I in danger of blowing something because of too much oil pressure? Also, is that an acceptable way of static timing a 650?
john in la
PostPosted: Sun May 08, 2016 4:45 pm    Post subject: Re: 1955 ford 650 hex shaft from distributor to oil pump Reply to specific post Reply with quote
If you have oil pressure the shaft has to be in right.
No way for the oil pump to turn without the shaft.
If the shaft were in wrong you would have 0 oil pressure.
It is common for oil pressure to be high at first start up due to cold thick oil.
As the engine warms up the pressure should go down.
Taking the shaft out and putting it back in has no effect on how much pressure the pump builds.
That is the pressure relief valve in the pump's job.
So if the pressure stays high even after warm up you either have a bad gauge or stuck pressure relief valve.
vharris4
PostPosted: Sun May 08, 2016 10:45 pm    Post subject: Re: 1955 ford 650 hex shaft from distributor to oil pump Reply to specific post Reply with quote
Thank you, very much. I'm glad I didn't mess that up. Even a blind squirrel will find an acorn sometime!
How about the timing? Is putting the flywheel at 8 deg and pointing the rotor at number one position on the distributor a good way?
Larry NCKS
PostPosted: Sun May 08, 2016 11:09 pm    Post subject: Re: 1955 ford 650 hex shaft from distributor to oil pump Reply to specific post Reply with quote
Good preliminary way. I'd either finish tuning by ear or by timing light. The latter would likely yield closer results!
vharris4
PostPosted: Sun May 08, 2016 11:46 pm    Post subject: Re: 1955 ford 650 hex shaft from distributor to oil pump Reply to specific post Reply with quote
Thanks!
