560 PTO ajusting tool
Hayfarmer
PostPosted: Tue May 10, 2016 5:18 pm    Post subject: 560 PTO ajusting tool Reply to specific post Reply with quote
I asked for some direction on building a tool to adjust the 560 PTO with external adjustment. I have seen it in the service manual but needed some direction. I was surprised with all the knowledge here that no one offered a suggestion. I have since removed the box and figured out how to build a tool that will work to push the lock away from the adjuster. I am willing to share my tool configuration with others who may have a question.
kevinj54
PostPosted: Wed May 11, 2016 2:11 am    Post subject: Re: 560 PTO ajusting tool Reply to specific post Reply with quote
CVPost-hayfarmer wrote:
(quoted from post at 21:18:11 05/10/16) I asked for some direction on building a tool to adjust the 560 PTO with external adjustment. I have seen it in the service manual but needed some direction. I was surprised with all the knowledge here that no one offered a suggestion. I have since removed the box and figured out how to build a tool that will work to push the lock away from the adjuster. I am willing to share my tool configuration with others who may have a question.
I would be interested in that even tho mine is still working good.
Hayfarmer
PostPosted: Wed May 11, 2016 6:51 am    Post subject: Re: 560 PTO ajusting tool Reply to specific post Reply with quote
The tool shown in the tech manual is a piece of metal with several bends. I had and old medium sized screw driver with about an 8 inch shank. I bent it approximately 1 1/2 inches from the outer end about 60 degrees. I was going to put more bends in it like the tool has but found with the pto brake in position per the book, put screw driver in adjustment hole, bent tip down, it will push against the lock button to release it. If you have the service book this will be more clear.
kevinj54
PostPosted: Wed May 11, 2016 3:33 pm    Post subject: Re: 560 PTO ajusting tool Reply to specific post Reply with quote
I have the books and have looked at the drawings.
Some day when I have to adjust I will make up a tool
