Author |
Message |
Tpartington New User
Posted: Sun May 15, 2016 8:21 am Post subject: Working my Super H |
I have 5 parked acres with some rocks and small bush stumps what could I put on my super to keep the bush and grass down. |
Back to top |
FBH44 Tractor Guru
Posted: Sun May 15, 2016 9:11 am Post subject: Re: Working my Super H |
You'll have to avoid the rocks and stumps, but a rotary mower of some sort is what I's recommend, WITH THE CHAIN GUARDS INSTALLED! Run the mower set up high, to avoid the rocks and stumps. The stumps will eventually rot away, after a number of years, but the rocks will stay until you pick them up. Easy way to pick up rocks... [ready?] [ ta da!!!] ... is gloves and a 5 gallon bucket. |
Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 36297 Location: St. Cloud, MN
Posted: Sun May 15, 2016 1:52 pm Post subject: Re: Working my Super H |
If you can't see the rocks/stumps, a flail mower could be useful. Jim |
Back to top |
David G Tractor Guru
Posted: Sun May 15, 2016 3:16 pm Post subject: Re: Working my Super H |
I agree, I think a rotary works better once the tough stuff is gone. |
Back to top |
Roger Tomfohrde Long Time User
Posted: Sun May 15, 2016 4:56 pm Post subject: Re: Working my Super H |
Depend on how big the rocks are. My wife's relatives near Green Bay use a D-7 Cat with a rock rake to clear their fields first. |
Back to top |
GeneMO Tractor Guru
Posted: Mon May 16, 2016 7:12 am Post subject: Re: Working my Super H |
CVPost-fbh44 wrote: | (quoted from post at 10:11:17 05/15/16) You'll have to avoid the rocks and stumps, but a rotary mower of some sort is what I's recommend, WITH THE CHAIN GUARDS INSTALLED! Run the mower set up high, to avoid the rocks and stumps. The stumps will eventually rot away, after a number of years, but the rocks will stay until you pick them up. Easy way to pick up rocks... [ready?] [ ta da!!!] ... is gloves and a 5 gallon bucket. |
Better put an overrunning clutch on that brush hog!!
Gene |
Back to top |
