Colder Plug for 641 with high compression pistons
anwalker
PostPosted: Tue Jun 28, 2016 4:55 pm    Post subject: Colder Plug for 641 with high compression pistons Reply to specific post Reply with quote
So I ordered a rebuild kit this winter and instead of coming with stocker flat top pistons it came with dome tops. Not knowing any better the autoparta guy crossed the al437 with the champion rc12lc4. My engine is diessling bad and the plug shows symptoms of being lean. I think I may need to jump to a colder non resistor plug? Suggestions?
Royse
PostPosted: Tue Jun 28, 2016 5:46 pm    Post subject: Re: Colder Plug for 641 with high compression pistons Reply to specific post Reply with quote
Autolite 216 or Champion H10 would be cooler than the 437.
I don't know about the ones you have in there.
mmfan55
PostPosted: Tue Jun 28, 2016 5:49 pm    Post subject: Re: Colder Plug for 641 with high compression pistons Reply to specific post Reply with quote
How fast does it idle ?? Many times
dieseling is a result of gas still
getting sucked through the carburetor
because the throttle is open too far.
If idling too fast changing plugs will
accomplish very little.
anwalker
PostPosted: Tue Jun 28, 2016 5:51 pm    Post subject: Re: Colder Plug for 641 with high compression pistons Reply to specific post Reply with quote
CVPost-mmfan55 wrote:
(quoted from post at 18:49:36 06/28/16) How fast does it idle ?? Many times
I beleive it's set at 550 right now. She's still going through breakin.
mmfan55
PostPosted: Tue Jun 28, 2016 6:36 pm    Post subject: Re: Colder Plug for 641 with high compression pistons Reply to specific post Reply with quote
Sometimes on my pulling tractors: I
will grab hold of the carburetor
linkage or throttle shaft when I shut
it down and push it closed to avoid
dieseling. Some governors tend to
allow the throttle to open a bit as
the engine rpm slows.
anwalker
PostPosted: Tue Jun 28, 2016 6:39 pm    Post subject: Re: Colder Plug for 641 with high compression pistons Reply to specific post Reply with quote
(quoted from post at 19:36:12 06/28/16) Sometimes on my pulling tractors: I
Now that I think about it, I haven't adjusted the governor springs yet.
Dean
PostPosted: Tue Jun 28, 2016 7:37 pm    Post subject: Re: Colder Plug for 641 with high compression pistons Reply to specific post Reply with quote
Spark plug heat range is likely not the problem.
Set the idle to 450 RPM or less and reduce the engine to idle speed before shut down.
Adjust the carburetor to obtain correct mixture under load.
Dean
David G
PostPosted: Wed Jun 29, 2016 4:31 am    Post subject: Re: Colder Plug for 641 with high compression pistons Reply to specific post Reply with quote
Dieseling is caused by idle set to fast, slow it way down.
RickB
PostPosted: Wed Jun 29, 2016 1:59 pm    Post subject: Re: Colder Plug for 641 with high compression pistons Reply to specific post Reply with quote
You are right about the guy not knowing any better selling you Champion plugs.
anwalker
PostPosted: Wed Jun 29, 2016 2:58 pm    Post subject: Re: Colder Plug for 641 with high compression pistons Reply to specific post Reply with quote
This tractor is how my grandfather made his living and the first time it's ever been rebuilt. Started it up to discover the new wedge seals were leaking, along with the radiator and oil filter adapter. I just put the oil pan back on last night and filled her back up with oil, hopefully I'll have the radiator back on this week. I still need to install a new set of points, change the plugs over to 437 or 216 autolite and get the timing dialed in, and adjust the idle down. I pulled the champion plugs yesterday and they were running leeeean. My timing light is on a permanent loan so I'll need to pickup another. Gotta get this thing going and back on the farm. Lots of work to do and running way behind.
David G
PostPosted: Thu Jun 30, 2016 11:29 am    Post subject: Re: Colder Plug for 641 with high compression pistons Reply to specific post Reply with quote
Plugs don't run lean, they are an indicator of what the engine is doing.
