Author |
Message |
Super A Regular
Posted: Tue Sep 27, 2016 8:14 am Post subject: Another Char-Lynn power steering question |
I'm purchasing a M that does not have power steering. It's going underneath a 2MH picker and I'd like to add a Char-Lynn torque generator to it. I've seen several posts about adapting different power steering pumps to run the torque generator, can anyone provide some NAPA numbers for these units? I'm most interested in the 50s era Cadillac pumps but the ones I find new online are pretty spendy. I'd like to set it up like the pic.
thanks,
Al
Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 16248 Location: Delta,colorado
Posted: Tue Sep 27, 2016 9:52 am Post subject: Re: Another Char-Lynn power steering question |
Go to an auto junkyard and buy something similar.Doesn't have to be a perfect 'match'. |
Back to top |
glennster Tractor Guru
Posted: Tue Sep 27, 2016 10:55 am Post subject: Re: Another Char-Lynn power steering question |
the napa number for that pump is NSP846551. it fits a 64 ford mustang. it does not come with the resevoir. there is a filter that fits in the resevoir, that is napa part number 1653. the pump uses the old type A transmission fluid. |
Back to top |
Posted: Tue Sep 27, 2016 10:58 am Post subject: Re: Another Char-Lynn power steering question |
if you look on ebay there are several of the eaton pumps for sale, there is a used one with the resevoir and pulley for 175.00 |
Back to top |
johninmn Regular
Posted: Tue Sep 27, 2016 12:27 pm Post subject: Re: Another Char-Lynn power steering question |
Where are you at? I might still have one identical to your picture id part with pretty easily. |
Back to top |
Super A Regular
Posted: Tue Sep 27, 2016 6:53 pm Post subject: Re: Another Char-Lynn power steering question |
I'm in eastern North Carolina.
thanks,
Al |
Back to top |
Super A Regular
Posted: Tue Sep 27, 2016 7:09 pm Post subject: Re: Another Char-Lynn power steering question |
How about a number for the reservoir?
thanks,
Al |
Back to top |
notjustair Tractor Guru
Posted: Tue Sep 27, 2016 7:32 pm Post subject: Re: Another Char-Lynn power steering question |
The one bad thing about your plan...
I have Char Lynn power steering on my M and it's the best thing since sliced bread. I put all new seals in the pump and torque motor when I put the tractor in service years ago. There aren't any leaks. Good thing - the hood has to come off to check the fluid with the reservoir up there. That might be a real main with a mounted picker.
Make sure you have a tight system. Taking off the muffler and climbing over that picker will get old really fast. |
Back to top |
PretendFarmer Tractor Expert
Posted: Wed Sep 28, 2016 2:37 am Post subject: Re: Another Char-Lynn power steering question |
Couldn't you run the torque motor off the belly pump? |
Back to top |
Super A Regular
Posted: Wed Sep 28, 2016 4:14 am Post subject: Re: Another Char-Lynn power steering question |
Belly pump is not live, so no power steering unless the clutch is not depressed.
Al |
Back to top |
Posted: Wed Sep 28, 2016 6:36 am Post subject: Re: Another Char-Lynn power steering question |
I'm aware of that. So you need it to be live then. |
Back to top |
Posted: Wed Sep 28, 2016 11:37 am Post subject: Re: Another Char-Lynn power steering question |
napa doesnt have the resevoir available, you have to use your old one. problem is , if you dont have an old one. |
Back to top |
