Power Steering line leak
Dchilds
PostPosted: Wed Nov 23, 2016 8:08 am    Post subject: Power Steering line leak Reply to specific post Reply with quote
Does anyone have a brief explanation on how to fix a leak in the power steering line (from pump to valve/steering column) on a Ford 3000? I have a pin hole leak at the elbow where the line turns down toward the pump.
It appears to have been soldered at some point and that's now failing. I was thinking maybe cut the elbow out and replace with some kind of 45 degree fitting....have to use/rent a flare tool (which I have not experience with).
Any help is appreciated.
BobReeves
PostPosted: Wed Nov 23, 2016 9:13 am    Post subject: Re: Power Steering line leak Reply to specific post Reply with quote
Had a fitting leaking on my 3000. Removed the line and took it to a local shop that made me a new line complete with the proper bends. A local hydraulic hose shop may be able to help or point you to someplace that will.
Dchilds
PostPosted: Wed Nov 23, 2016 7:35 pm    Post subject: Re: Power Steering line leak Reply to specific post Reply with quote
CVPost-BobReeves wrote:
(quoted from post at 10:13:28 11/23/16) Had a fitting leaking on my 3000. Removed the line and took it to a local shop that made me a new line complete with the proper bends. A local hydraulic hose shop may be able to help or point you to someplace that will.
I called a local guy who said he could fix it - "no problem". I'll take it over early next week to see what he can do. Thanks for the suggestion!
jtwat
PostPosted: Thu Nov 24, 2016 6:19 pm    Post subject: Re: Power Steering line leak Reply to specific post Reply with quote
You have to braze steel lines to repair. Solder will not stay.
If the hole is at the 90* bend, you may be able to cut it out and replace the bend with a 90* brass compression fitting.
