MF model 43 two bottom plow
Eric Keef
PostPosted: Sun Nov 27, 2016 5:28 am    Post subject: MF model 43 two bottom plow Reply to specific post Reply with quote
The right plow trips out as soon as I start with it.
Ive reset it every time.
What do I need to do?
JD Seller
PostPosted: Sun Nov 27, 2016 5:54 am    Post subject: Re: MF model 43 two bottom plow Reply to specific post Reply with quote
I would bet the latch is stuck and not working correctly. SO once you tripped it, now it is not locking.
Leroy
PostPosted: Sun Nov 27, 2016 7:00 am    Post subject: Re: MF model 43 two bottom plow Reply to specific post Reply with quote
You need to take it apart and clean out all the dirt and rust and put back together. And while you are doing that check parts to make sure they are not broken in any way. I had a MF 4 bottom semi mount and it had been drilled for a shear bolt as the top corner of the beam that was supposed to connect with the latch part had been broken off on all the beams. If you are luckey it will just be dirt and you may be able to pick as much out as you can while washing it out with a pennetrating oil. Not likely tho.
Eric Keef
PostPosted: Mon Nov 28, 2016 2:03 am    Post subject: Re: MF model 43 two bottom plow Reply to specific post Reply with quote
are there any springs in it?
Leroy
PostPosted: Mon Nov 28, 2016 8:25 am    Post subject: Re: MF model 43 two bottom plow Reply to specific post Reply with quote
I do not remember but likely. You need to find a parts book to know what there is in there as it could be dangerous.
BushogPapa
PostPosted: Mon Nov 28, 2016 1:14 pm    Post subject: Re: MF model 43 two bottom plow Reply to specific post Reply with quote
Yes, dis-mantle and clean it out good. check for failed springs and grease as you re-assemble..
Last resort, Weld the release so it will not release.. not usually and problem if you are not grossly over-powering the plow..
Eric Keef
PostPosted: Mon Nov 28, 2016 5:28 pm    Post subject: Re: MF model 43 two bottom plow Reply to specific post Reply with quote
that's what I was worried about. something blowing out in my face
wellmax99
PostPosted: Tue Nov 29, 2016 6:29 am    Post subject: Re: MF model 43 two bottom plow Reply to specific post Reply with quote
another guy had the same problem with his MF43 plow, when it hit the ground one of the plows tripped and would not reset, he had been plowing and hit roots,
(trip was a great option, but like a slip clutch on a bush hog or hay baler, it much be maintenance and cleaned from time to time to work properly,
___________________________
supposedly the (torsion spring) inside the trip action was broken,
part number: agro parts book #475365M2 item 35
good luck finding it on their parts list.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
