1923 Fordson F
donharmon
PostPosted: Wed Dec 21, 2016 6:48 pm    Post subject: 1923 Fordson F Reply to specific post Reply with quote
Rebuilding a 1923 Fordson F and trying to get it to start now but not having much luck?? Its a hand crank and turns over pretty hard as inside is new. Any ideas on quick starting other then waiting till summer and the weather reaches 80 degrees?? Has steel wheels front and back so have to keep on the dirt. hasn't run in 60 years as far as I can answers to. Just brain pickin so all answers will help?? Thnks
Greg NE
PostPosted: Wed Dec 21, 2016 7:06 pm    Post subject: Re: 1923 Fordson F Reply to specific post Reply with quote
Don't try to pull start it, may tear out the worm drive. Easiest way is to belt up a running
tractor to your Fordson to spin it over. That is if your Fordson has a pulley and if you have
access to another tractor that has a belt pulley on it. My 2 cents worth Greg NE
Royse
PostPosted: Wed Dec 21, 2016 7:07 pm    Post subject: Re: 1923 Fordson F Reply to specific post Reply with quote
One easy option would be to pull/push start it.
Does an F have a belt pulley? If so I have seen other Fordsons
belt started from another tractor. Also seem them converted to
electric start by putting a flywheel in place of the belt pulley
and building a bracket to mount an electric starter.
cushman
Does it have a pulley that you could use to belt up to another tractor? We have a 1923 Fordson also, and they are not an easy starting
tractor,but fun to drive when they do get started.
Dean
PostPosted: Wed Dec 21, 2016 11:03 pm    Post subject: Re: 1923 Fordson F Reply to specific post Reply with quote
As Cushman suggests, belt it to another tractor.
Pull starting a Fordson is problematic due to the worm gear final drive.
Dean
donharmon
PostPosted: Thu Dec 22, 2016 4:15 pm    Post subject: Re: 1923 Fordson F Reply to specific post Reply with quote
Thnks to all replies,am trying to figure a belt set up on it now as I have a 50 alli with a pulley drive on it under the seat so ?? on how I can get those two together and perform that task??
cdmn
PostPosted: Thu Dec 22, 2016 5:07 pm    Post subject: Re: 1923 Fordson F Reply to specific post Reply with quote
You'll need to block the tractors so the belt stays tight. Also, you may have to twist the belt to get the right direction of spin. You should have a helper. You'll be leaning over
the belt to adjust choke, ignition, etc., so be careful. Look at computer videos for ideas.
Search for "English Fordson starting 001"
