Spark Plugs
SawTooth 78
PostPosted: Thu Jan 05, 2017 1:37 pm    Post subject: Spark Plugs Reply to specific post Reply with quote
hi guys, back to spark plugs again we got a "C" with autolite plugs(386) in it , was looking for plugs to fit tried the NGK AB6 plugs to big, looking for a plug to fit it must be a 18mm or it will not fit, the 386 plugs work but a little to big we got it out after some work any ideas.
View user's profile AIM Address
D beatty
PostPosted: Thu Jan 05, 2017 2:07 pm    Post subject: Re: Spark Plugs Reply to specific post Reply with quote
If you have a NAPA or any good auto supply should be able to cross your to number of other plug that will work.
Janicholson
PostPosted: Thu Jan 05, 2017 3:19 pm    Post subject: Re: Spark Plugs Reply to specific post Reply with quote
Chase the threads in the head with a spark plug thread chasing tap. I have never encountered "tight" threads, or fat threads
on on the plugs. Jim
gene bender
PostPosted: Thu Jan 05, 2017 4:08 pm    Post subject: Re: Spark Plugs Reply to specific post Reply with quote
Like other post says chase the threads
Tom Fleming
PostPosted: Thu Jan 05, 2017 5:17 pm    Post subject: Re: Spark Plugs Reply to specific post Reply with quote
If plugs aren't seated completely, they will "leak" combustion gasses, and carbon will build up in the threads. It can also happen if you run too rich for too long. In any case, plugs can become almost impossible to take out.
3rd time is a charm: chase the threads.
John M
PostPosted: Thu Jan 05, 2017 5:46 pm    Post subject: Re: Spark Plugs Reply to specific post Reply with quote
The 386 plug is right, (Or 3116) so if they don't fit right, something else is wrong, not the plug.
BarnyardEngineering
PostPosted: Fri Jan 06, 2017 4:41 am    Post subject: Re: Spark Plugs Reply to specific post Reply with quote
I suspect that by "too big" he means the spark plug body's fit into the recess in the head. It is a tight fit, but...
Like others have said, the Autolite 386 is one of the correct plugs for that tractor. It is the exact same physical size as the original spark plugs that the tractor came equipped with. There are no plugs to fit that tractor with a smaller body.
You need a thin walled socket to install and remove the spark plugs on Farmall tractors from that era.
