881 thrust washer
Brian J in MN
PostPosted: Tue Feb 28, 2017 2:34 pm    Post subject: 881 thrust washer Reply to specific post Reply with quote
Anyone know where I can get the thrust washer for the D planetary? One I have is showing wear and the end play is .005 out of spec. I know it's probably not that much but I want to be safe rather than sorry.
Or if some of you other sos guru's have ran them with more end play on the output shaft your input would be appreciated.
Thanks,
Brian
Larry NCKS
PostPosted: Tue Feb 28, 2017 6:34 pm    Post subject: Re: 881 thrust washer Reply to specific post Reply with quote
End play could change with different C2C3. I believe I'd wait and see. I didn't pay particular attention the one I have when I disassembled the rear of transmission. Presumably I could still identify which one it is.
Larry NCKS
PostPosted: Thu Mar 02, 2017 5:37 pm    Post subject: Re: 881 thrust washer Reply to specific post Reply with quote
Laughing Glad u like the C2C3. Blessings for reassembly
Brian J in MN
PostPosted: Thu Mar 02, 2017 8:43 pm    Post subject: Re: 881 thrust washer Reply to specific post Reply with quote
Larry,
The thrust washer that goes on the main shaft between the C3 hub and the C ring gear does it go between the snap ring on the main shaft and the ring gear or does it go between the C3 clutch hub and the snap ring?
I could kick myself for not remembering when I took it apart.
Brian
Larry NCKS
PostPosted: Fri Mar 03, 2017 1:24 am    Post subject: Re: 881 thrust washer Reply to specific post Reply with quote
I believe it surrounds the snap ring, does it not? It certainly does not go between the snap ring and C2C3.
Brian J in MN
PostPosted: Fri Mar 03, 2017 8:50 am    Post subject: Re: 881 thrust washer Reply to specific post Reply with quote
Yep goes around snap ring. So it goes between snap ring and C ring gear hub.
Thanks Larry, just wasn't sure.
Brian
