Collar shift
danofarming
PostPosted: Fri Apr 07, 2017 7:08 pm    Post subject: Collar shift Reply to specific post Reply with quote
What would "collar shift" mean in the description of a deere 5320 tractor?
Bob
PostPosted: Fri Apr 07, 2017 7:43 pm    Post subject: Re: Collar shift Reply to specific post Reply with quote
A basic example of a "sliding gear" transmission.
A basic example of a "collar shift" transmission.
tim s
PostPosted: Sat Apr 08, 2017 5:16 am    Post subject: Re: Collar shift Reply to specific post Reply with quote
Nice explanation Bob...
JD Seller
PostPosted: Sat Apr 08, 2017 5:33 pm    Post subject: Re: Collar shift Reply to specific post Reply with quote
Bob did a great job explaining how a collar shift works. On a JD 5320 you have three options for transmissions: 1) cheapest, collar shift. So you basically have to be setting still to shift without grinding the gears. 2) Top shaft synchronized. Meaning the shifts other than the range shifts are synchronized. Meaning you can shift while moving slow and not grind gears. 3) Power reverser. With this one you have range and speed shifters but you have a forward and reverse in just about all of the gears. This shuttle is hydraulic and can be done without clutching the tractor.
