John Deere 260 Disc Mower. SCORE.
Goto page 1, 2  Next
Bryce Frazier
PostPosted: Tue Jul 25, 2017 7:30 pm    Post subject: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
Picked up a JD 260 (Kuhn) disc mower at an auction the other day. It appears to be in pretty good shape, other than a little rust, and a broken hay knife. Pto shaft is stuck, and I have yet to be able to slide it, but other than that, everything turns and works!?
I was thinking about using it behind my Super M, but when I hooked it up to the M (one with 3 point) I felt like it was heavy and awquard, even on that big of a machine?
How much power / weight does it take to run one, and what is it worth? Would I be out of like to say I should be able to get $3000 out of it? Maybe less? Thoughts?! Thanks!!
Also SCORED this JD plow for $75! Flawless other than a broken share, but I have a few spares for a 55 (which I think is what this one is). 2 x 16 plow. Very nice condition.
Bryce Frazier
PostPosted: Tue Jul 25, 2017 7:36 pm    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
Pictures
Bryce Frazier
PostPosted: Tue Jul 25, 2017 7:47 pm    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
Another thing I was going to ask, but forgot. This mower clearly doesn't have a "crimper" or conditioner of any kind, such as my IH 990 Swather does. Is one not needed? Explain that to me!
ohiodick
PostPosted: Tue Jul 25, 2017 7:54 pm    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
the super m is a little light to run that.
RodinNS
PostPosted: Tue Jul 25, 2017 7:57 pm    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
As best I can recall, the GMD 66 calls for something like 45 hp to drive it. As far as handling... you probably want a 7k pound tractor or better, moreso if you're on steep ground. I seldom run one on less than a Ford 5000, and generally not that small. IN terms of value... I suppose it's worth what you suggest if it works. The killer with these things is you don't know how long someone ran it without oil before you got it. Get it on the air, vertical... and find the drain plug on the bottom of the bar and the bevel gearbox. Drain them both and see what kind of crap comes out. If it's not full of metal you probably got a good one. Refill to the respective level plugs with 80W90 (the bevel gearbox must be filled with the bar horizontal, level with the same plug you drained it from. Also observe the bar for leaks once you get ti running. After you shut it down, raise it up and look for tracers... they can sometimes leak from the gear pinions... or the outer bar seal ring... or wear a hole in the bar pan. Beyond that the GMD is a nearly indestructible bar. Put a new set of knives in it. Keep the belts TIGHT (about 3/4" deflection in the center of the span) and keep lots of grease on the shaft joints. Eventually the jackshaft bearings will fail. Replace them and install a grease nipple in the center of the bearing housing (leave the inner seals off the bearings)... and you'll get a good long while from them after that.
Rod
RodinNS
PostPosted: Tue Jul 25, 2017 7:59 pm    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
You can get by without it. Just takes longer to dry...
Rod
Tx Jim
PostPosted: Wed Jul 26, 2017 2:23 am    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
CVPost-ohiodick wrote:
(quoted from post at 22:54:01 07/25/17) the super m is a little light to run that.
Super M at 47 belt HP should handle the 8' disc cutter. I've pulled a 9' disc cutter just fine with a JD 2040(40 pto HP) & Kubota M4900(45 pto HP).
Moonlite37
PostPosted: Wed Jul 26, 2017 2:32 am    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
I do not think a Super M would be a good choice to use with a disc mower. You need an outlet to raise the bar plus the one you use with the lift arms. Most 3 point kits have the end of the lift arms farther behind the axel which would make the tractor light on the front. Also the engine horsepower is marginal
ptfarmer
PostPosted: Wed Jul 26, 2017 3:05 am    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
It's worth 3 times as much as you paid for it just because it has JD decals on it :lol:. If it had the Kuhn decals you would be lucky to get what you paid for it. On another note if you had a disk mower caddy for it so you don't have all of its weight hanging off the back of the super M it would probably be ok.
Pair-a-dice farm
PostPosted: Wed Jul 26, 2017 3:36 am    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
I've got a Kuhn disc mower that is close to the same thing. They are a good machine. I have a tedder that lets me bale at least a day earlier. I have mine on a 4630 Ford and it's a little light, I wouldn't want to use it in tall hills. My 856IH handles it better but I keep it on the baler. The 1st thing you want to do is change the oil in the cutter bar and gearbox and check for wear. The discs should be tight. If it's been sitting a while you may want to polish the pulleys, the belts will grab if there is much rust and will twist. When I got mine it was nearly new but had been sitting for a couple of years. I put a banded belt on instead of the 4 belts. It helped a lot.
In my area $3000 would be on the high side because there are a lot of disc mowers around for sale. I would say $2-2500 in this neck of the woods.
bg/mo
PostPosted: Wed Jul 26, 2017 6:35 am    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
is it just the way the pic is ...or is lift cylinder bent....that mower has had a lot of hay through it
David from Kansas
PostPosted: Wed Jul 26, 2017 6:43 am    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
Looks like a model 52, or maybe a 44 JD plow but I think the shares are all the same.
Part Time Pete
PostPosted: Wed Jul 26, 2017 9:11 am    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
I can't tell on your plow, but we have a model 44, and I found that some have slow speed bottoms, and some have high speed. Turns out ours has the slow speed bottoms, and the points don't stand up well to our bony soil - and they aren't available any longer
Pete
Bryce Frazier
PostPosted: Wed Jul 26, 2017 10:47 am    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
I am not totally sure on the plow now? Mine has those flat arms, with the non adjustable coulters, just depth can be changed. Not the normal 1 1/2 round shaft like most plows had. This one has 1 piece moldboards, and on piece shares as well.
gene bender
PostPosted: Thu Jul 27, 2017 11:40 am    Post subject: Re: John Deere 260 Disc Mower. SCORE. Reply to specific post Reply with quote
Its a mower not a hay conditioner
Goto page 1, 2  Next
Page 1 of 2
