robgIN or others, how do I install the pump?
n9lhm
PostPosted: Thu Jul 27, 2017 4:25 pm    Post subject: robgIN or others, how do I install the pump? Reply to specific post Reply with quote
So I've got this belly pump all ready to mount on my F-20, and........ it won't fit. It looks like there is enough clearance for the pump to sit in there after it's on the mounting studs, but you can't get it over the studs without running into the clutch housing. So how do you mount it? You don't have to unbolt the whole engine and move it forward, do you?
robgIN
PostPosted: Thu Jul 27, 2017 4:36 pm    Post subject: Re: robgIN or others, how do I install the pump? Reply to specific post Reply with quote
Its been a few years but I think I installed mine while I had the clutch out. It is pretty easy to remove the clutch cover and that would give you the clearance you need, easier than moving the engine forward .
n9lhm
PostPosted: Thu Jul 27, 2017 7:04 pm    Post subject: Re: robgIN or others, how do I install the pump? Reply to specific post Reply with quote
OK, looking at the parts book, the clutch cover is definitely what is in the way, however, if I take the clutch cover off and mount the pump, how do I get the clutch cover back on? It looks like you need a 2" or better straight shot to get the clutch shaft back in the pressure plate and the pilot bearing?
used red MN
PostPosted: Fri Jul 28, 2017 2:40 am    Post subject: Re: robgIN or others, how do I install the pump? Reply to specific post Reply with quote
No idea about the configuration your working with, but could you double nut the studs remove them and reinstall once it is in place?
used red MN
PostPosted: Fri Jul 28, 2017 2:47 am    Post subject: Re: robgIN or others, how do I install the pump? Reply to specific post Reply with quote
Should add for you to beware if the studs screw in the transmission side the lube may leak out the holes when their out. So you may have to drain down the rear end to below the stud hole level during the pump install. FYI, I have rarely been around any F20, so shooting in the dark.
BruceS
PostPosted: Fri Jul 28, 2017 5:37 am    Post subject: Re: robgIN or others, how do I install the pump? Reply to specific post Reply with quote
yes, you do have to move the engine forward to get clearence. I can't see that removing the clutch cover would work. you'd have the same problem with clearance when putting it back.
robgIN
PostPosted: Fri Jul 28, 2017 8:46 am    Post subject: Re: robgIN or others, how do I install the pump? Reply to specific post Reply with quote
if you rotate the clutch cover as you go in , it will go. That's how I have done it on two different F-20s with belly pump
robgIN
PostPosted: Fri Jul 28, 2017 1:40 pm    Post subject: Re: robgIN or others, how do I install the pump? Reply to specific post Reply with quote
I didn't move the engine forward to do the two of mine. The shaft that engages the clutch disc can be pulled out of the clutch cover also and then put in after the cover is in place. You do not have to move the engine forward.
robgIN
PostPosted: Fri Jul 28, 2017 1:44 pm    Post subject: Re: robgIN or others, how do I install the pump? Reply to specific post Reply with quote
also you can take the pilot shaft out of the clutch cover and get the cover in place and then put the pilot shaft back through the cover into the clutch disc. Pretty sure that is what I did because I have never moved the engine forward to install anything.
