861 question
DD in WA
PostPosted: Sat Jul 29, 2017 4:42 am    Post subject: 861 question Reply to specific post Reply with quote
Underneath the tractor yesterday and I notice near the small hole with the cotter pin that lets oil drip out there is a plate about 5 inches square held on by four bolts. What is this plate for and what's
underneath it? Thought it would be easier to ask than actually remove it and possible create a problem I don't currently have.
Thanks,
riveroadrat
PostPosted: Sat Jul 29, 2017 5:13 am    Post subject: Re: 861 question Reply to specific post Reply with quote
Its a weep hole, cotter pin keeps it cleaned out. If you have a leak in tranny input or rear main engine seal it will leak out of the weep hole. Thick oil is gear oil from tranny, thin oil is rear engine seal. If its a diesel the engine oil will be black.
DD in WA
PostPosted: Sat Jul 29, 2017 5:27 am    Post subject: Re: 861 question Reply to specific post Reply with quote
Understand about the weep hole, interested about the 5 inch plate. Is it just access into that same area?
tractorguy2
PostPosted: Sat Jul 29, 2017 5:48 am    Post subject: Re: 861 question Reply to specific post Reply with quote
Sounds like it could be the cover for the pressure relief valve for the hydraulic system.
john in la
PostPosted: Sat Jul 29, 2017 6:47 am    Post subject: Re: 861 question Reply to specific post Reply with quote
The plate is just a inspection cover into the clutch area.
showcrop
PostPosted: Sat Jul 29, 2017 4:05 pm    Post subject: Re: 861 question Reply to specific post Reply with quote
CVPost-tractorguy2 wrote:
(quoted from post at 06:48:43 07/29/17) Sounds like it could be the cover for the pressure relief valve for the hydraulic system.
The pressure relief cover is triangular with three screws last Looked.
