Securing a Farmall cub
jsfarmall
PostPosted: Wed Aug 30, 2017 5:18 pm    Post subject: Securing a Farmall cub Reply to specific post Reply with quote
I have a 16ft dual axle trailer I haul my cubs on. What is the best/preferred way to strap/chain a cub down.
muleboss
PostPosted: Wed Aug 30, 2017 6:27 pm    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
Tight
grandpa Love
PostPosted: Thu Aug 31, 2017 4:39 am    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
Opening a can of worms. We use 2 nylon straps. One over transmission. One around drawbar. No issues yet . Some will say chains, binders ect.
ericlb
PostPosted: Thu Aug 31, 2017 6:47 am    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
i tie mine down by taking a 3 or 4 inch nylon strap from the front of the trailer then over the front axle and under the engine, then over the axle on the other side and back to the front of the trailer ,tighten, then on the back, i run from the back of the trailer up around the draw bar then back the the other side of the trailer tighten the cub between the 2 and it will stay
showcrop
PostPosted: Thu Aug 31, 2017 6:11 pm    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
Look at the next post down "securing Formal 230".
jsfarmall
PostPosted: Fri Sep 01, 2017 6:23 pm    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
Ok so not much different than I have done. I take a strap around the front axle to the trailer. 1 on each side then a chain and binder on the drawbar. Just wanted to see if anyone had a better idea
D beatty
PostPosted: Sat Sep 02, 2017 7:21 am    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
I would like to ask you a question. You have strap over trans. which holds tractor down and one on draw bar to keep tractor from going forward. What keeps it from rolling backwards?
ztrmowers
PostPosted: Sat Sep 02, 2017 7:24 am    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
i ways always told if on public road needs 4 seperate points of tiedown regardless size of unit.i got stopped once hauling lawn tractors same theory needs 4 points.
showcrop
PostPosted: Sat Sep 02, 2017 9:09 am    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
CVPost-ztrmowers wrote:
(quoted from post at 08:24:42 09/02/17) i ways always told if on public road needs 4 seperate points of tiedown regardless size of unit.i got stopped once hauling lawn tractors same theory needs 4 points.
Not true, at least according to FSMCA. It applies only to over 10.000 lbs which is also where 3/8 chain or heavy straps kicks in.
D beatty
PostPosted: Sat Sep 02, 2017 6:45 pm    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
From what I have read all vehicles are to be tied down so they can't move forward or backward or from side to side.
john *.?-!.* cub owner
PostPosted: Thu Sep 07, 2017 6:34 pm    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
A fellow on Farmallcub dot com sells an attachment that olts to the front axle pivot and has both a hitch receiver for backing trailers, and a tie down loop under it. Real handy item.
jsfarmall
PostPosted: Sat Sep 09, 2017 11:43 am    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
I'm a welder myself and thought about
building one but was curious how strong
the front end pivot point was for
strapping down.
PostPosted: Sat Sep 09, 2017 7:55 pm    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
Cubs are not noted for strong front ends, but they are plenty strong for tying down.
caterpillar guy
PostPosted: Thu Sep 28, 2017 2:42 pm    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
Oh I would just throw the straps over the hood and pull'em down then one over the seat good to go. Now for the serious side if you put a chain over the front axle and to the opposite side of the trailer then one to the drawbar back to the trailer it will be fine and hold securely to the trailer.
mattofvinings
PostPosted: Thu Sep 28, 2017 11:21 pm    Post subject: Re: Securing a Farmall cub Reply to specific post Reply with quote
When I trailered my Cub, I put 2 chains around the horizontal front axle tube, and 2 around the drawbar. The two on the front were mostly straight-ahead and the ones on the drawbar went more out to the sides. Never had any issues this way. Used a smaller dia chain, may have even been 1/4" dia links and some matching cam-over load binders that I got at a Farm Fleet store somewhere. Just had to manage the pressure on the load binders to be reasonable.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting All times are GMT - 8 Hours
