Using a uhaul for hauling AND hay rides
Goto page 1, 2  Next
RoadrunnerTrading
PostPosted: Thu Aug 31, 2017 6:12 am    Post subject: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
Hi everyone, I'd like to rent an open trailer to haul my jubilee about 60 mi. I would like to then use that same trailer behind the tractor to pull the kids around for some short hay rides. Is this a possibility? Is there any place to find a smaller diameter shank for a 2 inch ball hitch that I can use on the tractor? I was thinking the 6x12 open box trailer from uhaul. It's for some high rails
On it that would be perfect for hayrides, I'm just not sure how to tow it behind the jubilee. Any ideas or suggestions would be appreciated. Thanks!
ericlb
PostPosted: Thu Aug 31, 2017 6:36 am    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
first do you have the under the tractor draw bar? my jube does, and for hay rides i use a 8 by 18 trailer loaded with people the jubilee has no problem pulling it, but its also fairly level around the farm, dont use the 3 point type draw bar, it places the trailer too far back of the rear axle and makes the tractor too light on the front axle, for a cheat, if you buy one of the 11 hole draw bars that fits the 3 point linkage and cut one of the pins off it will fit under the tractor provided the brackets are already there, you can then use a standard 2 inch ball , for hauling the jubilee you do need a tandem axle trailer, using a single axle trailer is dangerous as all get, out as you cant get the load weight correct to prevent the trailer from whipping you all over the road
RoadrunnerTrading
PostPosted: Thu Aug 31, 2017 8:08 am    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
CVPost-ericlb wrote:
(quoted from post at 07:36:11 08/31/17) first do you have the under the tractor draw bar? my jube does, and for hay rides i use a 8 by 18 trailer loaded with people the jubilee has no problem pulling it, but its also fairly level around the farm, dont use the 3 point type draw bar, it places the trailer too far back of the rear axle and makes the tractor too light on the front axle, for a cheat, if you buy one of the 11 hole draw bars that fits the 3 point linkage and cut one of the pins off it will fit under the tractor provided the brackets are already there, you can then use a standard 2 inch ball , for hauling the jubilee you do need a tandem axle trailer, using a single axle trailer is dangerous as all get, out as you cant get the load weight correct to prevent the trailer from whipping you all over the road
Thanks! I do have the under tractor draw bar. A couple of questions...
Is there enough clearance between the draw bar/ball and the pto in order to properly hitch the trailer? And, what diameter shank is your ball? I don't believe the standard 2in ball I have will fit in the hole of my draw bar. Thanks for the help!
jon f mn
PostPosted: Thu Aug 31, 2017 9:57 am    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
You can get balls with 3/4 shank which
should fit most drawbars.
View user's profile AIM Address
jon f mn
PostPosted: Thu Aug 31, 2017 10:04 am    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
Trailer sway is a matter of balance and has nothing to do with how many axles a trailer has. Most folks confuse a better pulling tandem trailer as being because of the extra axle when it is usually because of extra trailer length or the axle center being further back. As long as he gets propper tongue weight it will pull good regardless of how many axles. More important would be weight capacity, a single axle u-haul is likely rated at less than 3k capacity so not enough for an 8n.
D beatty
PostPosted: Thu Aug 31, 2017 3:00 pm    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
With a U Haul tandem axle trailer like he is talking about you can only haul 2,110 lbs. Max and a Ford Jubilee shipping weight starts at a little over 2,500 lbs. I have rented several UHaul trailers and are some of the worst trailer I have ever pulled and brakes on their trailers suck.
Tubacase47
PostPosted: Thu Aug 31, 2017 5:55 pm    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
It is my uderstanding that if U-Haul even suspects you are going to haul a tractor on one of their trailers, you won't get it.
ericlb
PostPosted: Mon Sep 04, 2017 12:05 pm    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
tounge weight is the problem with a tractor on a single axle, tractors have the 4 tires holding their weight, but they are not evenly balanced on the tires, most single axle trailers tend to be short and its not easy to get proper weight distribution
jon f mn
PostPosted: Tue Sep 05, 2017 3:30 am    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
That is exactly what I said, it's about balance a d not the number of axles that matter. If you had a long enough single axle so you could load properly it would trail as good or better than a tandem.
ss55
PostPosted: Tue Sep 05, 2017 5:30 am    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
You should be able to read an online copy of the U-Haul rental agreement before you rent. www.uhaul.com/Trailers/6x12-Utility-Trailer-With-Ramp-Rental/HO/ Will your tractor fit inside the 4 foot 9 inch rear opening? Without any weights your tractor will still overload that trailer and it may bend the ramp. I would look for a 7000 pound trailer.
What is the road speed of your tractor? 60 miles one way is not that far to drive a tractor in nice weather.
retired farmer
PostPosted: Tue Sep 05, 2017 11:09 am    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
I think U Haul would frown on you hauling people in one of their trailers even if it was just a hayride.
showcrop
PostPosted: Tue Sep 05, 2017 2:32 pm    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
CVPost-Retired Farmer wrote:
(quoted from post at 12:09:18 09/05/17) I think U Haul would frown on you hauling people in one of their trailers even if it was just a hayride.
I doubt that U-Haul would be worried. I expect that their contract states that any problems resulting from illegal use are not theirs. Carrying passengers on a trailer is illegal pretty much everywhere. I checked with my insurance company before offering my tractor and wagon for a hayride.
Leroy
PostPosted: Tue Sep 05, 2017 4:10 pm    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
If you try to rent a U Haul they want the exact make and model you are going to haul and if it does not meet their book specks you cannot rent. Several years ago tried to rent one to haul a broken down Buick and would not rent it because they sai a full size half ton chevy truck was not big enough to pull it. Friend ended up hauling it behind his F250 on a different friends trailer.
bobs old iron
PostPosted: Sun Sep 10, 2017 12:38 pm    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
with all responded post, my friend wanted to haul a ford explorer sport trac,, too heavy they said for their trailers, big deal by 500lbs. should have told them he are hauling a v-w,,, also on the idea of hauling people on it with hay,, caution: make sure you are covered , by club insurance etc, nice idea but somthing happens, who responceable
David G
PostPosted: Mon Sep 11, 2017 5:14 am    Post subject: Re: Using a uhaul for hauling AND hay rides Reply to specific post Reply with quote
You sure a 2" ball trailer is enough to pull that weight.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
