ramps
stonerock
PostPosted: Sun Sep 17, 2017 6:49 am    Post subject: ramps Reply to specific post Reply with quote
how many load narrow front tractors with two ramps? never had a trailer with 3 ramps. 26' with 5' dove tail the trick is gettin the fourth tractor on.....john deere 530-630 on first up front 730-730 on back, makes for a good load on a tandem. friend of mine hauls 3 -830 on his tandem, he's heaver than I am
D beatty
PostPosted: Sun Sep 17, 2017 10:11 am    Post subject: Re: ramps Reply to specific post Reply with quote
While they were building my new trailer I had them put the third ramp on. The ramp and spring assist only cost me a $139.00 while they were building it. I wouldn't have a trailer without one.
mmfan55
PostPosted: Sun Sep 17, 2017 10:17 am    Post subject: Re: ramps Reply to specific post Reply with quote
I have, still do on occasion. Depends a lot on trailer height and tractor. Some will load easy on 2 ramps, some not so easy.
casenut1
PostPosted: Sun Sep 17, 2017 6:59 pm    Post subject: Re: ramps Reply to specific post Reply with quote
Stonerock, missed you at the show today.The tractor I liked best was the 870 demonstrator.
grandpa Love
PostPosted: Mon Sep 18, 2017 3:58 am    Post subject: Re: ramps Reply to specific post Reply with quote
I've seen folks load on 2 ramps ,not for me. Much happier with third ramp.
showcrop
PostPosted: Mon Sep 18, 2017 4:13 am    Post subject: Re: ramps Reply to specific post Reply with quote
My big trailer has three ramps but my smaller one just two. I used to haul two NFE tractors on it with the front one backed on of course. I may have used a plank for the one that I backed on.
rustyfarmall
PostPosted: Mon Sep 18, 2017 4:46 am    Post subject: Re: ramps Reply to specific post Reply with quote
I've seen it done with 2 ramps. I even tried it myself one time, and I was succesful, but I much prefer using 3 ramps.
Mike M
PostPosted: Tue Sep 19, 2017 9:26 am    Post subject: Re: ramps Reply to specific post Reply with quote
3 ramps for me too ! I made my center one so it can lay flat on the beaver tail and you can leave it there if only loading wide front tractors. The outer ones would not slide in real narrow IIRC ? so the center ramp worked out good for small things like lawn mowers.
Kansas4010
PostPosted: Tue Sep 19, 2017 10:53 am    Post subject: Re: ramps Reply to specific post Reply with quote
I have the wide glide option so two ramps work for me.
RustyR
PostPosted: Tue Sep 26, 2017 1:07 pm    Post subject: Re: ramps Reply to specific post Reply with quote
I've done this multiple times. The trick is to start out 90 degrees to the trailer so the back tire will line up with the ramp, and then stand on that wheel brake and send the front wheels up the other ramp. Works slick once you get then hang of it. 3 ramps would of course be easier.
showcrop
PostPosted: Tue Sep 26, 2017 1:32 pm    Post subject: Re: ramps Reply to specific post Reply with quote
CVPost-RustyR wrote:
(quoted from post at 14:07:34 09/26/17) I've done this multiple times. The trick is to start out 90 degrees to the trailer so the back tire will line up with the ramp, and then stand on that wheel brake and send the front wheels up the other ramp. Works slick once you get then hang of it. 3 ramps would of course be easier.
I do it all the time because I have three four cylinder NFE Fords and a two ramp trailer. I do it from a 45 degree angle. I just carefully get the front wheels started up the right ramp turned at a fairly sharp angle then just drive up straightening as I go. Every now and then at a show or a pull someone will look at me like I have two heads.
caterpillar guy
PostPosted: Thu Sep 28, 2017 2:52 pm    Post subject: Re: ramps Reply to specific post Reply with quote
I've seen it done.For my stepdeck trailer the ramps have to be to long for that trick so I use the third one .It is about 3 feet shorter than the other 2. It is used for going from the bottom to the top deck in front.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting All times are GMT - 8 Hours
