Farmall C with a 7ft. 27V sickle bar combination?
Dave O'Brien
PostPosted: Sat Oct 28, 2017 2:09 pm    Post subject: Farmall C with a 7ft. 27V sickle bar combination? Reply to specific post Reply with quote
I'm thinking about trying this combination for pasture clipping and perhaps field use. I'm on moderately hilly ground and wondering if I might be underpowered for this set up to work with out a bunch of headaches. If anyone has done this, I'd like your opinions please.
Charlie M
PostPosted: Sat Oct 28, 2017 2:22 pm    Post subject: Re: Farmall C with a 7ft. 27V sickle bar combination? Reply to specific post Reply with quote
It doesn't take much horsepower to run a 7ft sickle bar. If you pasture has been eaten down it should be pretty easy to mow.
khouse6
PostPosted: Sat Oct 28, 2017 3:19 pm    Post subject: Re: Farmall C with a 7ft. 27V sickle bar combination? Reply to specific post Reply with quote
for clipping , use a clipping wheel
gene bender
PostPosted: Sat Oct 28, 2017 4:11 pm    Post subject: Re: Farmall C with a 7ft. 27V sickle bar combination? Reply to specific post Reply with quote
Thats what we used when the tractor was new so it will work just fine
Rick Remmert
PostPosted: Sat Oct 28, 2017 7:18 pm    Post subject: Re: Farmall C with a 7ft. 27V sickle bar combination? Reply to specific post Reply with quote
I have been running one for over 7 years. I run along in 2nd gear at about 3/4 throttle. You have to remember you are not grinding it up like a rotary mower. You are just cutting it off. I have mowed weeds tractor high and pasture 3" tall all at the same speed. Just keep it in adjustment and sharp sections on it.
gene bender
PostPosted: Sat Oct 28, 2017 7:40 pm    Post subject: Re: Farmall C with a 7ft. 27V sickle bar combination? Reply to specific post Reply with quote
You don't need a clipping wheel just tilt the bar so it cuts high
Brownie450
PostPosted: Sun Oct 29, 2017 4:07 am    Post subject: Re: Farmall C with a 7ft. 27V sickle bar combination? Reply to specific post Reply with quote
We would cut alfalfa in 3rd gear with ours.
Sharp sickle is needed.
27V is heavy on the SC. We broke the right
rear axle housing on the SC with the mower
on it one time, but had been mowing rough
pasture with it.
Good mower.
Jim
