D4 7u transmission noises
M. Stepan
PostPosted: Mon Nov 06, 2017 6:36 am    Post subject: D4 7u transmission noises Reply to specific post Reply with quote
its pretty loud runs great but could it be the the bearings in the tranny steering clutches its was sitting for 15 years got it running doesn't skip a beat but the transmission is loud its not in the finals any good advice would be great.
hector gemme
PostPosted: Mon Nov 06, 2017 10:31 am    Post subject: Re: D4 7u transmission noises Reply to specific post Reply with quote
Did you check the oil level in transmission first it could be the in master cluch
sms
PostPosted: Mon Nov 06, 2017 2:54 pm    Post subject: Re: D4 7u transmission noises Reply to specific post Reply with quote
I don't remember if that is a wet clutch but I do know you have to lubricate it. I don't have the manual here or I would give the details. Get a manual, lots of good stuff to know. Also did you drain and refill the transmission? Is it cold enough for ice in the tranny there?
MikeJM
PostPosted: Mon Nov 06, 2017 5:35 pm    Post subject: Re: D4 7u transmission noises Reply to specific post Reply with quote
What type of noise? Whine, growling, clunk? A lot of them have been worn out, patched up and worn out some more.
Steering clutch and brakes will be dry. Only the very late ones will have a wet main clutch.
M. Stepan
PostPosted: Wed Nov 08, 2017 12:39 pm    Post subject: Re: D4 7u transmission noises Reply to specific post Reply with quote
like metal on metal
hector gemme
PostPosted: Wed Nov 08, 2017 3:36 pm    Post subject: Re: D4 7u transmission noises Reply to specific post Reply with quote
You could desangaged the transmission and angaged the master cluch you could see if the noise is in cluch
DW1307
PostPosted: Sun Nov 12, 2017 7:31 am    Post subject: Re: D4 7u transmission noises Reply to specific post Reply with quote
You might try cracking the drain plug and see if you get any water, since you say it sat a long time. Sounds like bearings.
