mitsubishi BD2G Dozer
Tracy Brown
PostPosted: Sun Nov 12, 2017 1:29 pm    Post subject: mitsubishi BD2G Dozer Reply to specific post Reply with quote
I just noticed the track rail chains are worn out and need replaced. Where have some of you guys found to buy yours? To rebuild looks like a TON of welding. Is that even do-able. Also, I see that rubber tracks are available. Any suggestions or experience with those on a small dozer? Thanks
RBoots
PostPosted: Sun Nov 12, 2017 2:41 pm    Post subject: Re: mitsubishi BD2G Dozer Reply to specific post Reply with quote
Call a GOOD undercarriage dealer and they'll usually be able to match something up that has the same pitch. Rails aren't really something you weld up. I did UC work for a number of years from small ditch witch machines to PC750 excavators and D375 dozers. Not fun work, hard work, but I am getting rusty on some of it since I've gotten out of that line of work on a daily basis. Double check the specs, but if I remember correctly, on those small Mitsubishi dozers, they are able to use a Komatsu D21 dozer rail. Like I said, been a long time, but it seems that's what fit on those.
Ross
Frank Dodson
PostPosted: Sun Nov 12, 2017 7:37 pm    Post subject: Re: mitsubishi BD2G Dozer Reply to specific post Reply with quote
I have a BG2F and I think the under carriage will be the same. I had the under carriage rebuilt about 9 years ago. I bought the parts from Rhine Equipment located in Tacoma WA. I purchased rails, track shoes etc. They were pricey but new. Their phone number is 253-536-0600 and email www.rhineequipment.com. If you have rocks I would stay away from rubber tracks.
2x4
PostPosted: Sun Nov 12, 2017 10:50 pm    Post subject: Re: mitsubishi BD2G Dozer Reply to specific post Reply with quote
only cure for worn out rails is new ones. Nortrak in Nashville Tn. is where I got mine -JD 550G.
Tracy Brown
PostPosted: Tue Nov 14, 2017 2:15 pm    Post subject: Re: mitsubishi BD2G Dozer Reply to specific post Reply with quote
Well, I bit the bullet today. Ordered new chains, weld on sprocket rings, and new hardware set to re-mount the pads.
RBoots
PostPosted: Tue Nov 14, 2017 8:07 pm    Post subject: Re: mitsubishi BD2G Dozer Reply to specific post Reply with quote
Take your new sprocket rims and line them up on the old sprockets. Then either clamp or tack weld the new sprocket to the old one and use it for a template to cut off the old one. Make sure you make a hash mark across both pieces to line it back up when you go to weld it back on. Then do it like a truck rim with clamps on it, tack one side, set a block of wood next to that spot, then turn it slowly and tack the opposite side, work your way around it. Pretty easy job, good luck!
