case 580 -c
Joe Diver
PostPosted: Sat Nov 18, 2017 11:37 am    Post subject: case 580 -c Reply to specific post Reply with quote
i have a trans leak problem, i rebuilt the shuttle and now i have a leak from the torque converter access hole
in the bottom, torque converter is fine, i have rebuit a few of these but this is new, no leaks from shuttle all seals and gaskets are new naturally.
AJ.
PostPosted: Sat Nov 18, 2017 6:52 pm    Post subject: Re: case 580 -c Reply to specific post Reply with quote
This is a Case 580C you got with a Borg Warner Shuttle,have you checked the torque cake for a crack,it is not unusual for the housing to crack under the flexi mounting plate,the other place is the front oil seal in the pump,you sure the oil is not leaking from the breather and running to the lowest point,if it is remove the relief valve and have a look at the ball and spring,it's in the piece of hexagon on the shuttle plumbing.
AJ
Joe Diver
PostPosted: Sun Nov 19, 2017 8:01 am    Post subject: Re: case 580 -c Reply to specific post Reply with quote
no cracks in convrter, i will check the shuttle plumbing closer, let you know , thanks
Joe Diver
PostPosted: Mon Nov 20, 2017 1:58 pm    Post subject: Re: case 580 -c Reply to specific post Reply with quote
AJ I checked all the plumbing and the check valve and everything looked fine , my unit does not have a releif
valve on top
Joe Diver
PostPosted: Mon Nov 20, 2017 2:14 pm    Post subject: Re: case 580 -c Reply to specific post Reply with quote
AJ My bad, my breather on top is missing but was not leaking from there
AJ.
PostPosted: Thu Nov 23, 2017 6:24 pm    Post subject: Re: case 580 -c Reply to specific post Reply with quote
If you are sure the leak is coming out the drain hole then the leak is in side,there is nothing that can be done from the outside the shuttle will have to come out,if the cake is good and a new front seal you will need check the torque boss is not out of round where it goes through the seal,I have seen this happen when the unit was let fall down at the back during removal,the oil pump could have a leak/crack,it hard to guess where the oil could be coming from.
AJ
