IXB-3 Engine Head Gasket
KV Bruce
PostPosted: Sat Nov 18, 2017 6:29 pm    Post subject: IXB-3 Engine Head Gasket Reply to specific post Reply with quote
I finished the overhaul of my 1947 IXB-3 (in a BF Avery A model). I installed the head gasket clean but dry. Torqued cold to 35 ft lbs. (did not re-torque when warm, my bad). It leaked coolant into the oil. I am pretty sure the head is flat, real sure the block is flat. When I replace the head gasket should use a sealant? What product? I will re-torque after a warm up this time. Thanks for your consideration.
J. Schwiebert
PostPosted: Mon Nov 20, 2017 6:10 am    Post subject: Re: IXB-3 Engine Head Gasket Reply to specific post Reply with quote
MAKE Sure you use some sealant on the head bolts as some thread into the water jacket. MY e-mail should be open.
John Deere D
PostPosted: Wed Nov 22, 2017 9:26 am    Post subject: Re: IXB-3 Engine Head Gasket Reply to specific post Reply with quote
MAKE Sure you use some sealant on the head bolts as some thread into the water jacket:
Apply sealant with a NON METAL tool thinly such as a "Credit Card" on both sides of the gasket etc,:
I use this sealant on all heads and blocks that are not refaced:
Picture is for example purposes:
Bob...
KV Bruce
PostPosted: Mon Nov 27, 2017 8:28 am    Post subject: Re: IXB-3 Engine Head Gasket Reply to specific post Reply with quote
Thanks Bob,
I ended up using the Permatex spray on the head gasket and their thread sealer on the bolts. Did a hot re-torque and drove it almost 5 miles to and from our town's Christmas Parade. I really have learned quite a few things on this site. (better reading than the news!!) Thanks to all again.
Juicybusa2
PostPosted: Wed Dec 13, 2017 7:00 am    Post subject: Re: IXB-3 Engine Head Gasket Reply to specific post Reply with quote
According to all my sources Ixb3 head torques to 45 lb ft
Post new topic    Yesterday's Tractors Forum Index -> Lesser Known Classics All times are GMT - 8 Hours
