300 utility hyd. lines
Lee Tho
PostPosted: Wed Nov 22, 2017 1:36 pm    Post subject: 300 utility hyd. lines Reply to specific post Reply with quote
does any one know if the 300 utility hyd lines between the pump and unit have o rings or gaskets at each ends the manual I have does not show these lines when I bought this tractor the lines were off I tried o rings and they blew right out thanks in advance for any help lee
Duner Wi
PostPosted: Wed Nov 22, 2017 3:08 pm    Post subject: Re: 300 utility hyd. lines Reply to specific post Reply with quote
My 350U has "O" rings.
MARK ROBKE
PostPosted: Wed Nov 22, 2017 4:38 pm    Post subject: Re: 300 utility hyd. lines Reply to specific post Reply with quote
They are o rings.Mark
pinball
PostPosted: Thu Nov 23, 2017 5:40 pm    Post subject: Re: 300 utility hyd. lines Reply to specific post Reply with quote
Did you just buy o rings at your local parts store. I went to buy some o rings for my hydraulics on my dozer. Found some the same size at the local parts store but he couldn't answer my question about them being used In my hydraulics so I stopped by the cat place and asked them. they always replace any hyd hose I need and seem to be very knowledgeable. He told me you need the correct o ring for the hydraulics. Some will have low pressure and some hi pressure and the material there made of makes a big difference. I used his o rings and rebuilt my hydraulic controls and they have never leaked. Don't know if this will but good luck with your problem.
