FM 2 hp crank shaft bent
golfcartman
PostPosted: Thu Dec 07, 2017 5:47 pm    Post subject: FM 2 hp crank shaft bent Reply to specific post Reply with quote
I need a crankshaft for a Fairbanks Z 2 hp engine, or what is the chance of getting mine strengthened out. Can that be done? Let me know what you have or think on getting mine fixed. It's not bad, does fine at low rpm. Here is a picture of it.
Richard G.
PostPosted: Fri Dec 08, 2017 5:56 am    Post subject: Re: FM 2 hp crank shaft bent Reply to specific post Reply with quote
A good machine shop can straighten it and check it in a lathe. Preferably an older machine shop with guys that have been around for a while.
Richard in NW SC
Bob
PostPosted: Fri Dec 08, 2017 6:49 pm    Post subject: Re: FM 2 hp crank shaft bent Reply to specific post Reply with quote
If there's still an automotive machine shop in your area, the sort of place that rebores engine blocks and grinds crankshafts, they should be set up to check crankshafts, and straighten, as needed. Ask around.
travis miranowski
PostPosted: Sun Dec 10, 2017 11:18 am    Post subject: Re: FM 2 hp crank shaft bent Reply to specific post Reply with quote
Easy to true up yourself. Remove the flywheel from the bent side of the crank. Bolt the engine to a solid base, (concrete if possible and use a dial indicator to find the peak of the bend. Then use a hyd jack to gently straighten. Do it slow and keep checking with the indicator until the run out is gone. Also carefully check the flywheel for cracks at the spokes. Something struck the flywheel to bend and it may have cracked it in the process.
ed will
PostPosted: Wed Dec 13, 2017 7:08 pm    Post subject: Re: FM 2 hp crank shaft bent Reply to specific post Reply with quote
Hi, I think I have one plus block some gears.Ed Will Oliver BC
Post new topic    Yesterday's Tractors Forum Index -> Stationary Engines All times are GMT - 8 Hours
