2-70 White head gasket problems
Goto page 1, 2  Next
jacot14860
PostPosted: Wed Nov 29, 2017 5:48 am    Post subject: 2-70 White head gasket problems Reply to specific post Reply with quote
I have a white tractor (2-70) blowing coolant out of radiator. Doing an in frame now, after i replaced head gasket twice, had the head checked twice and shaved straight. It still blew coolant out of the radiator. Does anyone know what the liner protrusion should be? I need to get this tractor going thanks for any help.
Wisconsin Cowman
PostPosted: Wed Nov 29, 2017 7:41 am    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
Did you check if the block is flat? What brand of head gasket?
Oliver 500 Wa
PostPosted: Wed Nov 29, 2017 9:56 am    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
CVPost-jacot14860 wrote:
......had the head checked twice
Pressure tested?
Not on a tractor engine, but I had an engine with a crack around an exhaust valve that behaved how you describe.
chucksoliver77
PostPosted: Wed Nov 29, 2017 2:53 pm    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
Did you put new sleeves in it? If you did check the sleeves about 1/4 " down from the top for cracks. The new sleeves aren't made as good as the originals.
jacot14860
PostPosted: Wed Nov 29, 2017 5:29 pm    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
In the process of putting new liners in. I have to
shim three of them
jacot14860
PostPosted: Wed Nov 29, 2017 5:30 pm    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
Two machine shops both pressure tested head
jacot14860
PostPosted: Wed Nov 29, 2017 5:32 pm    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
I do need to check for straightness if deck. Good idea thanks. I think it?s a reliance in frame kit
RWT
PostPosted: Wed Nov 29, 2017 8:13 pm    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
1 to 4.
0.001 to 0.004
RT
oliver power
PostPosted: Thu Nov 30, 2017 3:32 am    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
too much coolant??? seams the olivers like radiator fluid tank half full/empty.
wilma
PostPosted: Thu Nov 30, 2017 4:57 am    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
Might also want to check the radiator (just for good measure). Had a 1650 come in for repairs and after running 20 minutes it would boil over. Problem was calcium clogged all the internal tubes inside the radiator, coolant had no where to go except out the cap.
jacot14860
PostPosted: Thu Nov 30, 2017 7:29 am    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
This tractor is eminently after starting. Thank you any help is appreciated
jacot14860
PostPosted: Thu Nov 30, 2017 7:31 am    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
Maybe but it does seem that it shouldn't push it right out after starting the tractor hmmm....
jacot14860
PostPosted: Thu Nov 30, 2017 7:37 am    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
Is there any common problems with the 283 diesel?
JBR
PostPosted: Thu Nov 30, 2017 9:17 am    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
I have had a issue close to yours with a reliance head gasket except it was bubbling compression out while running. The only reason I saw it was one of the fuel return tees was leaking fuel and running down on the head gasket. Mine wasn't leaking compression into the coolant that I know of it didn't run long enough to find out. I got a ago gasket coming and will let you know what I find when I get it apart. You could try to warm it up and re-torque it but I have never had luck with that. I think the reliance gaskets have a lot of room for emprovement. And this was on a complete OH for a 1655 all sleeve protrusion were in spec on mine.
wilma
PostPosted: Thu Nov 30, 2017 11:38 am    Post subject: Re: 2-70 White head gasket problems Reply to specific post Reply with quote
When you took the head off, did you notice where the head gasket failed, (i.e. in between cylinders)? Did you have any coolant in the oil pan? Did the engine get hot or very warm (normal heavy work under load) and then you noticed it boiling over? These are some of the things I've run into that can lead to gasket failure as these engines can be sensitive to over heating...(have been guilty of it myself). One other question, is the deck pitted around or near the fire ring on any or all cylinders?
Goto page 1, 2  Next
Page 1 of 2
