880
brian stanek
PostPosted: Tue Dec 12, 2017 5:23 pm    Post subject: 880 Reply to specific post Reply with quote
as you see all works good up till here. clutch shaft turns freely. shifts into gear easily but will not move the tractor?
J. Schwiebert
PostPosted: Tue Dec 12, 2017 7:18 pm    Post subject: Re: 880 Reply to specific post Reply with quote
When you say the clutch shaft turns freely you mean you can take hold of the shaft and turn it without pushing the clutch petal down? If so the hub is broke out of the clutch drive disk.
brian stanek
PostPosted: Wed Dec 13, 2017 8:25 am    Post subject: Re: 880 Reply to specific post Reply with quote
sorry I should explain it better than I did, the engine is now disconnected from the trans. it would not move the tractor in any gear. however it worked fine up till the power booster then nothing from there back. I now have taken the power booster out of the equation. when turning the trans shaft by hand with tractor in gear the shaft spins freely. so something is wrong inside. can I take the ft aluminum cover off the trans housing or will open up a complete can of worms? thanks for any help.
J. Schwiebert
PostPosted: Wed Dec 13, 2017 8:53 am    Post subject: Re: 880 Reply to specific post Reply with quote
My e-mail is open, send me a reply with phone number. J.
brian stanek
PostPosted: Wed Dec 13, 2017 7:32 pm    Post subject: Re: 880 Reply to specific post Reply with quote
thanks very much. I couldn't locate your email. mine is mopargtx1970@gmail.com. send me an email and ill send you a ph. no, thanks again.
brian stanek
PostPosted: Thu Dec 14, 2017 10:32 am    Post subject: Re: 880 Reply to specific post Reply with quote
CVPost-J. Schwiebert wrote:
(quoted from post at 17:53:21 12/13/17) My e-mail is open, send me a reply with phone number. J.
so my ph. no is 250-547-6244
