Author |
Message |
jr1983 Long Time User
Posted: Fri Jan 12, 2018 5:24 am Post subject: Utu front end cover |
What do you do for a replacement on the top cover for the front end of a UTU? Agco pn UT5800A. I am in the rust belt and all five of the u front ends I have the top cover is rotted through. Makes it hard to keep water out. Do you make a new one or are they available some where? I have not tried agco as its an hour drive to the nearest one. |
Back to top |
Posted: Fri Jan 12, 2018 5:41 am Post subject: Re: Utu front end cover |
Guess I should add I have never had one apart with enough left to use it as a design if I need to fabricate one. |
Back to top |
F-MM Regular
Posted: Fri Jan 12, 2018 5:55 am Post subject: Re: Utu front end cover |
Our 50 utu had one of those thin plates on it that was all rusted out too and it had allowed water to run down inside and freeze and that split the casting. I have a non running 51 utu so I switched front ends on the two and realized that one had a much heavier plate for a cover, like maybe 1/4" metal. It is a little bit different too as I recall it extends out a little further where the hood latch hooks down but I made it work and look original. You could probably make one but like you said, you need a pattern but you could try drawing a cardboard one first to cover the area. |
Back to top |
jwuertz Regular
Posted: Fri Jan 12, 2018 6:44 am Post subject: Re: Utu front end cover |
If I remember correctly Welters in Missouri had them for sale. |
Back to top |
Scout2008 Regular
Posted: Fri Jan 12, 2018 10:17 am Post subject: Re: Utu front end cover |
JWuertz, please email me. I have a couple questions for you. |
Back to top |
Kevin Moschenrose Long Time User
Posted: Fri Jan 12, 2018 7:42 pm Post subject: Re: Utu front end cover |
I will have to look out in my parts box but I think I have a good one. I can check tomorrow and see. |
Back to top |
UB-ToMMy Regular
Posted: Sun Jan 14, 2018 3:32 pm Post subject: Re: Utu front end cover |
Years ago I had a pedestal cover made for my UB. I made a drawing from the original cover and gave the drawing and the original cover to the sheet metal place to make.
I must have put the holes in it later using the original part since the drawing doesn't show any holes.
Back to top |
WGM Tractor Expert
Posted: Sun Jan 14, 2018 7:30 pm Post subject: Re: Utu front end cover |
I made a new cover for my UB using 14ga galvanized iron. |
Back to top |
Posted: Sun Jan 14, 2018 7:51 pm Post subject: Re: Utu front end cover |
CVPost-UB-ToMMy wrote: | (quoted from post at 00:32:49 01/15/1 Years ago I had a pedestal cover made for my UB. I made a drawing from the original cover and gave the drawing and the original cover to the sheet metal place to make.
This looks absolutely awesome. Thank you very much. I am not a sheet metal expert but I'm pretty sure I can get it done from this. Thanks again. |
Back to top |
UB-ToMMy Regular
Posted: Wed Jan 17, 2018 6:16 pm Post subject: Re: Utu front end cover |
Didn't realize the copy would show up so blurry. If you need a better copy, email me and I'll send you a PDF. |
Back to top |
Posted: Wed Jan 17, 2018 7:18 pm Post subject: Re: Utu front end cover |
CVPost-UB-ToMMy wrote: | (quoted from post at 03:16:26 01/18/1 Didn't realize the copy would show up so blurry. If you need a better copy, email me and I'll send you a PDF. |
My email is open and I would appreciate a PDF greatly. I done see where your contact is open. |
Back to top |
Posted: Wed Jan 17, 2018 7:25 pm Post subject: Re: Utu front end cover |
Back to top |
