Help with 885 I.D. number
Goto page 1, 2  Next
ScottNC
PostPosted: Sat Jan 06, 2018 10:16 am    Post subject: Help with 885 I.D. number Reply to specific post Reply with quote
Looked at a DB885 this morning. Front end loader covered the area on the right frame where I understand the I.D. tag to be located. I did however find a number on the right side frame just behind the radiator sheetmetal: 885 163707. The 885 is obvious but the 6-digit number... is it a shortened serial number? Should it read 1101633707 making the tractor a '79 model?
ScottNC
PostPosted: Sat Jan 06, 2018 10:17 am    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
EDIT does not work, the number I meant to type in was 110163707.
RGMartin
PostPosted: Sat Jan 06, 2018 10:29 am    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
Could be... Have a picture of the number by chance?
Spin on oil filter or a canister type with a bolt in the middle?
Tach say "smiths" or "AC" on it?
ScottNC
PostPosted: Sat Jan 06, 2018 11:36 am    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
RGMartin wrote:
(quoted from post at 11:29:17 01/06/1Cool Could be... Have a picture of the number by chance?
No picture but I spent considerable time scratching off the paint and scrutinizing the numbers... maybe I can answer what you want to know?
Have the owner checking on the filter and tach.
ScottNC
PostPosted: Sat Jan 06, 2018 12:54 pm    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
Okay, canister type oil filter, tach has DAVID BROWN along the bottom of the face and the letters AC located (in the owner words) in the middle, upper front.
Those stamped numbers on the frame-- are ballpark. 3/8" tall in a Redbird looking font. Due to paint, view angle due to loader and light I could not tell if the numbers were stamped individually ( I think they were but..) or from a fixed type stamp. there is a two to three digit space between the 885 and the 1.
RGMartin
PostPosted: Sat Jan 06, 2018 1:14 pm    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
Not a 79, They quit the canister type filter in 1976-77 or so, went to spin on. Possible an older block they had hiding somewhere, but unlikely.
Just as likely the serial number is re stamped when the front frame was replaced.
Why does the year matter? At 40+ years old condition is much more important.
Orange chassis, or brown?
ScottNC
PostPosted: Sat Jan 06, 2018 2:17 pm    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
RGMartin wrote:
(quoted from post at 14:14:03 01/06/1Cool Not a 79, They quit the canister type filter in 1976-77 or so, went to spin on. Possible an older block they had hiding somewhere, but unlikely.
Number is on the frame facing up on the horizontal flat section immediately behind the radiator tin. Was looking for the I.D. plate when I spotted bits of it under the paint.
Orange chassis.
The current owner had never heard of a thermostart and had no idea one was on his tractor. Before seeing if it works... actually asking questions on how to use it it seemed prudent to first figure out what it was I was asking questions about.
On to the thermostart--is it ignition switch activated or is there a dedicated something? Can I tell if it is working by feeling for heat assuming the is power and fuel to it? The owner has no manual for the tractor. IF it becomes mine I will come up with appropriate operator and service literature.
RGMartin
PostPosted: Sat Jan 06, 2018 2:29 pm    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
Thermostart is activated by turning the key past run to a spring loaded position half way to "start" The decal on the switch will say "heat".
Not a big deal to fix if it isn't working.
Joe (Wa)
PostPosted: Sat Jan 06, 2018 3:02 pm    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
Go to this link, DB885 info near the bottom of the page. Hop over to page 2, s/n info and parts manual.
Joe
https://sites.google.com/site/deerebrown/
ScottNC
PostPosted: Sun Jan 07, 2018 3:27 pm    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
Thanks for the help guys!
ArleninOr
PostPosted: Sun Jan 07, 2018 6:01 pm    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
RG, I have an 885 bought new in 1979 and it is a cartridge oil filter. Have a 78 model and it is also not a spin on. Have a 1 owner 1190 with a cartridge oil filter also. So am not sure when they changed them. Now I am confused, Easily done in my case.
RGMartin
PostPosted: Sun Jan 07, 2018 7:00 pm    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
All I have encountered after 77 are spin on. The 77 was bought new by my family.
I guess another of those DB mysteries.
Jim in Sask
PostPosted: Sun Jan 07, 2018 9:12 pm    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
When they went to a spin-on filter did they use an adapter or was there a change to the block itself? My 885 serial number dates it as a 1977 and it has the cartridge filter.
RGMartin
PostPosted: Mon Jan 08, 2018 3:50 am    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
Different block. I have thought about making some adapter plates, it would be a pretty simple lathe project. Keeping me from doing it is the fact that the cartridge filter is reasonably enough priced when you buy by the case.
Arlen, does your 1190 use the 1313 filter like the your 885s, or is it a longer filter? The parts books show a longer cartridge type for the 1190/94 but I have never encountered one. I have never had an 1190, but all 3 1194s are the spin on.
ArleninOr
PostPosted: Mon Jan 08, 2018 9:19 am    Post subject: Re: Help with 885 I.D. number Reply to specific post Reply with quote
RG, different filter # if I remember. Will have to look. Have 2 990's same year. 1 spin on, one cartridge. Go figure.
Kind of like women I guess. Never able to figure them out either.
Goto page 1, 2  Next
Page 1 of 2
