Ignition switch broke on 450.. now, how do I hot wire it
Goto page Previous  1, 2
MeanGene1
PostPosted: Wed Jan 10, 2018 7:38 am    Post subject: Re: Ignition switch broke on 450.. now, how do I hot wire i Reply to specific post Reply with quote
Jim, did they all have the same key, and is it available? If someone just lost the original key on mine, maybe I could put it back stock, as the original switch and button are still there
D beatty
PostPosted: Wed Jan 10, 2018 10:17 pm    Post subject: Re: Ignition switch broke on 450.. now, how do I hot wire i Reply to specific post Reply with quote
Switch is easy to get to and replace.Just take panel with gauges out and is easy to reach.
OldFarmall450
PostPosted: Thu Jan 11, 2018 5:54 am    Post subject: Re: Ignition switch broke on 450.. now, how do I hot wire i Reply to specific post Reply with quote
Thanks D, mine is where your cigarette lighter is, maybe easier to get to then yours.
Jim, mine was definitely a replacement, probably from a vehicle, cause it had too many positions. Working OT today and Friday, ill get back to it soon.
MeanGene1
PostPosted: Thu Jan 11, 2018 8:16 am    Post subject: Re: Ignition switch broke on 450.. now, how do I hot wire i Reply to specific post Reply with quote
Mine also has the aftermarket switch where the lighter was, made me suspect that someone lost the original key and did a workaround
OldFarmall450
PostPosted: Thu Jan 11, 2018 9:18 am    Post subject: Re: Ignition switch broke on 450.. now, how do I hot wire i Reply to specific post Reply with quote
Looking closely I notice you have a different light switch. I have the silver 3 position turn knob. Of course it doesn't work.
D beatty
PostPosted: Fri Jan 12, 2018 6:58 am    Post subject: Re: Ignition switch broke on 450.. now, how do I hot wire i Reply to specific post Reply with quote
When I was doing tractor I couldn't find a three position knob so I put in a three position push- pull switch. I now know where to get
original switch so some day when I have time I will change it out.
MeanGene1
PostPosted: Fri Jan 12, 2018 8:34 am    Post subject: Re: Ignition switch broke on 450.. now, how do I hot wire i Reply to specific post Reply with quote
So, are the original keys available? I would like to see if mine could work with the original switch and push button
BarnyardEngineering
PostPosted: Fri Jan 12, 2018 10:28 am    Post subject: Re: Ignition switch broke on 450.. now, how do I hot wire i Reply to specific post Reply with quote
IH used the exact same ignition key from the 450 all the way through to the end in 1985.
Current IH part number is 131313C1 and if you give an experienced locksmith the code "A1146" they can program their key cutting machine to cut one for you.
Page 2 of 2
