The 105 in Question
Goto page Previous  1, 2
GreenEnvy
PostPosted: Mon Jan 08, 2018 8:00 pm    Post subject: Re: The 105 in Question Reply to specific post Reply with quote
BigBud W
Here is a link to one of my 55s.
GreenEnvy
PostPosted: Mon Jan 08, 2018 8:02 pm    Post subject: Re: The 105 in Question Reply to specific post Reply with quote
Try again
https://m.youtube.com/watch?v=O6qljFn9Law
tomstractorsandtoys
PostPosted: Tue Jan 09, 2018 10:04 am    Post subject: Re: The 105 in Question Reply to specific post Reply with quote
Do not take my reply as trying to be nasty or know it all. Maybe instead of saying the brochure was wrong I should have just said what we have done? I have 23.1 x 26 tires on the 105 and run a 13 ft head. In rye that is often taller than me and usually down flat I would not want a bigger head. I have found with a 13ft header in soybeans with the 95 I sometimes want to drive to fast and do not get a good of a cutting job. Tom
3020G
PostPosted: Tue Jan 09, 2018 11:35 am    Post subject: Re: The 105 in Question Reply to specific post Reply with quote
I would prefer a 15' or 16' head to go on the 105 but the 13' is what I have found. Also it's what it currently has to go with it.
The combine seems funny to me because for it's day the combine was the biggest Deere had. It has a 4 Row wide and 13' heads so basically the smallest heads to go on the machine. Also it is only a 2 stick cab. Gas, Gear Drive. No AC, No Heat, No Chopper,and No Bin Extension.
I'm by far no 105 expert but those are the things I picked up right away that are not on it.
If anyone in the south west Indiana area (Including IL, IN, KY) that has the stuff to make the clean grain auger longer and bin extension I would be interested. Possibly a chopper.
JK2
PostPosted: Tue Jan 09, 2018 2:15 pm    Post subject: Re: The 105 in Question Reply to specific post Reply with quote
About 40 years ago, I replaced all the floor and half way up on the back side of the 15'or 16' head on my 1966 105 combine with galvanized 16 gauge sheet metal. Also replaced the sheets on the ends with the same material. It is all bolted on. If I remember correctly, some of the original was riveted. Check the inside of the auger before you start since they rust inside from sitting out also. Replace the steel fingers with new poly ones to prevent damage to the auger etc.
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
Page 2 of 2
