7710 loader plumbing
MNfarmer
PostPosted: Tue Jan 09, 2018 3:51 am    Post subject: 7710 loader plumbing Reply to specific post Reply with quote
I've been reading through old posts about
how to plumb in a joystick loader valve on
a 7710 series 2 Ford and I'm having
trouble finding a gresen v20ls which was
mentioned as the correct valve to use.
Can someone point me in the right
direction?? Thanks
Bern
PostPosted: Tue Jan 09, 2018 5:27 am    Post subject: Re: 7710 loader plumbing Reply to specific post Reply with quote
It doesn't have to be a Gresen V20LS, that's simply the valve I used 20 plus years ago when I did that same job. Just call your local hydraulic shop and tell them you need a 2-spool, 20 GPM closed center load sensing valve. You'll also want a float section for the loader lift spool.
TinCan
PostPosted: Tue Jan 09, 2018 7:22 am    Post subject: Re: 7710 loader plumbing Reply to specific post Reply with quote
CVPost-Bern wrote:
(quoted from post at 06:27:52 01/09/1Cool You'll also want a float section for the loader lift spool.
What is that, and what does it do?
I am looking at parts (control valve) I need to get for my loader.
Thanks, Pat
Bern
PostPosted: Tue Jan 09, 2018 8:46 am    Post subject: Re: 7710 loader plumbing Reply to specific post Reply with quote
A float spool is one with 4 distinct positions, unlike the 3 spool typically has. Most spools have a lower-neutral-raise position. A float spool has float-lower-neutral-raise. The float position allows the loader arms to follow the contour of the ground, and is usually detented. It is not mandatory.
MNfarmer
PostPosted: Tue Jan 09, 2018 11:05 am    Post subject: Re: 7710 loader plumbing Reply to specific post Reply with quote
Thanks Bern!
TinCan
PostPosted: Tue Jan 09, 2018 11:19 am    Post subject: Re: 7710 loader plumbing Reply to specific post Reply with quote
CVPost-Bern wrote:
(quoted from post at 09:46:13 01/09/1Cool A float spool is one with 4 distinct positions, unlike the 3 spool typically has. Most spools have a lower-neutral-raise position. A float spool has float-lower-neutral-raise. The float position allows the loader arms to follow the contour of the ground, and is usually detented. It is not mandatory.
Ok, you mean like a draft on the 3-point.
Thanks, Pat
Bern
PostPosted: Tue Jan 09, 2018 12:24 pm    Post subject: Re: 7710 loader plumbing Reply to specific post Reply with quote
No, I would not equate that to a 3-point hitch at all. A 3-point cylinder is single acting, whereas your loader cylinders are double acting. Float position simply means that the oil in a double acting cylinder can exit or transfer between both sides of a piston at will.
Imagine taking a cylinder with no hoses attached and pulling the rod in and out with your hand. That would be "float action".
David G
PostPosted: Tue Jan 09, 2018 3:07 pm    Post subject: Re: 7710 loader plumbing Reply to specific post Reply with quote
I did that on my 6610.
You need a CCLS valve, tee into the line that goes to the SCV for supply, and tee into the sense line with shuttle T
MNfarmer
PostPosted: Tue Jan 09, 2018 4:12 pm    Post subject: Re: 7710 loader plumbing Reply to specific post Reply with quote
Is this the correct line to T into for the supply?
TinCan
PostPosted: Tue Jan 09, 2018 4:21 pm    Post subject: Re: 7710 loader plumbing Reply to specific post Reply with quote
What I meant was, that it followed the ground, moving up & down, and not rigid. Not as to what the insides do.
Pat
Bern
PostPosted: Tue Jan 09, 2018 8:28 pm    Post subject: Re: 7710 loader plumbing Reply to specific post Reply with quote
Yes
Tx Jim
PostPosted: Wed Jan 10, 2018 4:12 am    Post subject: Re: 7710 loader plumbing Reply to specific post Reply with quote
TinCan wrote:
(quoted from post at 14:19:33 01/09/1Cool
Thanks, Pat
Draft on 3 pt is load sensing causing 3 pt hitch to raise/lower due to amount pulling pressure exerted on 3 pt. Nearly all tractor models have a 3 pt that can float.
As Bern stated float position on loader valve allows boom cylinders to move in/out to follow ground contour.
MNfarmer
PostPosted: Thu Jan 11, 2018 6:00 pm    Post subject: Re: 7710 loader plumbing Reply to specific post Reply with quote
Ok thanks. Where does the shuttle T get plumbed in that I've read about and also the load sensing line?
