3000 spark plug problem
Lynn Patrick
PostPosted: Tue Jan 09, 2018 9:17 am    Post subject: 3000 spark plug problem Reply to specific post Reply with quote
When I bought this 3000 it had quite a mess w/the plug wires - one insulated w/duct tape - so I ordered a complete tune up kit from this site. Now it runs great most of the time but I can't keep the plug boots down on the plugs. I push them on, twist them on, hold them on for a while, whatever else I can think to try, but they slowly raise up & pop loose, sometimes immediately, sometimes a day later. Is there supposed to be some kind of clip or something that keeps them from popping loose?
Thanks!
Lynn
johnofnewhaven
PostPosted: Tue Jan 09, 2018 11:05 am    Post subject: Re: 3000 spark plug problem Reply to specific post Reply with quote
Hi. When I put new plug wires on mine
it did the same thing. Use a pair of
needle nose pliers and pull the wire
out of the boot a little. Secure the
wire on the plug then work the boot
down snug on the head.
Fordfarmer
PostPosted: Tue Jan 09, 2018 12:39 pm    Post subject: Re: 3000 spark plug problem Reply to specific post Reply with quote
Sometimes an indication of exhaust gasses
escaping past the spark plug. Are the plugs tight?
Sean in PA
PostPosted: Tue Jan 09, 2018 1:35 pm    Post subject: Re: 3000 spark plug problem Reply to specific post Reply with quote
CVPost-fordfarmer wrote:
(quoted from post at 16:39:46 01/09/1Cool Sometimes an indication of exhaust gasses
Even if they're in tight you can get gasses bypassing the plug if they are cheap plugs. I have seen brand new Chinese made plugs that have a hole the length of the ceramic insulator next to the electrode core so you can blow on one end and air comes out the other end. Guy at the parts store said that they had been seeing a bunch like that getting returned lately. It almost looks like they drilled two holes through the insulator because the first one wasn't centered.
Lynn Patrick
PostPosted: Tue Jan 09, 2018 1:45 pm    Post subject: Re: 3000 spark plug problem Reply to specific post Reply with quote
Thanks guys! Fordfarmer, I rechecked the plugs & they're tight. The boots have been popping off even when the tractor was not running!
John, I tried your suggestion & it feels like that might work! At least they have stayed on all afternoon (I haven't started the tractor though). I had thought about pulling there but was afraid I would pull the clip off the wire. Time will tell!
Thanks again!
David G
PostPosted: Tue Jan 09, 2018 3:06 pm    Post subject: Re: 3000 spark plug problem Reply to specific post Reply with quote
I do not think the clip is snapping on the plug, as suggested, slide it down the boot make sure it snaps, then slide boot back down
marcusmerritt
PostPosted: Tue Jan 09, 2018 5:43 pm    Post subject: Re: 3000 spark plug problem Reply to specific post Reply with quote
2000 Ford 3 cyl. gas; 4/1....I'm having the same problem with a new set of plug wires. Have tried pulling the wire clip down further in the rubber boot but am afraid to pull too hard because the clip may detach from the wire. It appears that the problem is the 'hat brim' of the boot hangs on the sleeve at each plug preventing the boot from going any further into the sleeve. If I can't get the clip further down am gonna put the boot on my belt sander and remove enough so the wire will clip onto the plug. Most frustrating to get a product (this is the second set with this problem) that doesn't work like it should.
Lynn Patrick
PostPosted: Wed Jan 10, 2018 1:53 pm    Post subject: Re: 3000 spark plug problem Reply to specific post Reply with quote
Took the tractor out for a short time today & the plug boots stayed on! It took very little pulling on the clip to make it work.
Thanks All!
johnofnewhaven
PostPosted: Wed Jan 10, 2018 3:20 pm    Post subject: Re: 3000 spark plug problem Reply to specific post Reply with quote
Great! Little things like that can
drive you crazy!
