1959 Case 210B hydraulic bypass filter?
Goto page 1, 2  Next
smc81c
PostPosted: Tue Jan 09, 2018 6:28 pm    Post subject: 1959 Case 210B hydraulic bypass filter? Reply to specific post Reply with quote
Hey all, I searched the forum and found the part numbers for the bypass filter I'm looking for. Which is the
Marvel Engineering Co. Bypass Filter Element
NSN: 4330-00-918-8077
P/N M-2032-135-35
I cannot for the life of me find one or cross reference it to another part on the internet.
Can anybody steer me in the right direction for a replacement filter?
Stephen Newell
PostPosted: Tue Jan 09, 2018 6:59 pm    Post subject: Re: 1959 Case 210B hydraulic bypass filter? Reply to specific post Reply with quote
I believe the one I have is a wire mesh. I just cleaned mine with lacquer thinner and blew it out with compressed air.
smc81c
PostPosted: Tue Jan 09, 2018 7:12 pm    Post subject: Re: 1959 Case 210B hydraulic bypass filter? Reply to specific post Reply with quote
my filter is crushed/collapsed from some other mister fix it prior to getting my fingers in it. The filter seems to be unobtainium.....i did get a quote from a place for 375$ for one filter.
Case Nutty 1660
PostPosted: Wed Jan 10, 2018 4:42 am    Post subject: Re: 1959 Case 210B hydraulic bypass filter? Reply to specific post Reply with quote
I am just guessing you are talking the one on the loader hyd and not this one? If so I am sure I have a book on that as well but will have to dig a bit
cnt
Stephen Newell
PostPosted: Wed Jan 10, 2018 5:19 am    Post subject: Re: 1959 Case 210B hydraulic bypass filter? Reply to specific post Reply with quote
There is a G13113 on ebay for 18.84.
oldproudvet
PostPosted: Wed Jan 10, 2018 7:10 am    Post subject: Re: 1959 Case 210B hydraulic bypass filter? Reply to specific post Reply with quote
Mine on my 310B hoe/loader is a mesh cleanable one. Mine was missing and I got a great one from our Knuk neighbor, Jean Claude Marleau, he monitors this and has an excellent stash of new and used parts
Joe (Wa)
PostPosted: Wed Jan 10, 2018 10:25 am    Post subject: Re: 1959 Case 210B hydraulic bypass filter? Reply to specific post Reply with quote
The original filter element was a cleanable edge wound type. It is in series with the oil return circuit not a bypass. They hole and/or collapse due to differential pressure when clogged or from system high back pressure.
The element is original Case p/n G13113. John Saeli sells the element. Also a suitable substitute disposable type element is Wix 51518.
Joe
http://www.wixfilters.com/Lookup/PartDetails.aspx?Part 76951
Joe (Wa)
PostPosted: Wed Jan 10, 2018 11:36 am    Post subject: Re: 1959 Case 210B hydraulic bypass filter? Reply to specific post Reply with quote
"The element is original Case p/n G13113. John Saeli sells the element. Also a suitable substitute disposable type element is Wix 51518."
Ooops, I was addressing the tractor internal hydraulic return oil filter shown in CNT pic. After reading the thread more closely, as I should have done in the first place, not sure what filter element you need.
Joe
Case Nutty 1660
PostPosted: Wed Jan 10, 2018 12:11 pm    Post subject: Re: 1959 Case 210B hydraulic bypass filter? Reply to specific post Reply with quote
Or this one maybe
cnt
smc81c
PostPosted: Wed Jan 10, 2018 2:14 pm    Post subject: link to what im looking for from this sight Reply to specific post Reply with quote
http://www.yesterdaystractors.com/case/messages/208332.html
smc81c
PostPosted: Wed Jan 10, 2018 2:18 pm    Post subject: Re: link to what im looking for from this sight Reply to specific post Reply with quote
it is the filter that is above the rectangular reservoir on the right side of the tractor. its a stainless mesh type filter that is cleanable. has a pipe tread on one end
smc81c
PostPosted: Wed Jan 10, 2018 3:07 pm    Post subject: Re: 1959 Case 210B hydraulic bypass filter? Reply to specific post Reply with quote
that looks like the filter housing and filter. I think I may have tracked down a new part number D21008=C28783.
smc81c
PostPosted: Wed Jan 10, 2018 5:57 pm    Post subject: Re: 1959 Case 210B hydraulic bypass filter? Reply to specific post Reply with quote
still looking for a place to source a filter. any leads would be great.
Stephen Newell
PostPosted: Wed Jan 10, 2018 6:37 pm    Post subject: Re: 1959 Case 210B hydraulic bypass filter? Reply to specific post Reply with quote
https://www.ebay.com/itm/Lube-Oil-Filter-for-Case-International-A36524-A39578-A51463-D32211-G13113/192245331216?hash=item2cc2b6f510:i:192245331216
Joe (Wa)
PostPosted: Wed Jan 10, 2018 8:01 pm    Post subject: Re: 1959 Case 210B hydraulic bypass filter? Reply to specific post Reply with quote
Both these pics are from Case parts substitution manual dtd 1989. Generally it is the same part with just a p/n change.
1. Note that D21008 cross-ref to R2799. This is an old manual p/n's may have changed again.
2. C28783 just gives an outside source, does not state whether it is a filter or not.
3. Two C28783 filters listed available as CasIH parts at this link. You'll have to confirm it is the filter you need. I don't know how to order from this site, I think you may have to do it through a Case dealer. Anyway if you figure out how to order please post back the procedure.
Joe
http://parts.depotparts.com/Parts/Single/StartsWith/A/C28783/
Goto page 1, 2  Next
Page 1 of 2
