Help to identify bolt
BrianLivingstone
PostPosted: Wed Jan 10, 2018 9:27 am    Post subject: Help to identify bolt Reply to specific post Reply with quote
Can someone please tell me the purpose of the bolt circled in the picture. I thought it was a drain plug until I removed it
Thanks . Brian
BrianLivingstone
PostPosted: Wed Jan 10, 2018 9:29 am    Post subject: Re: Help to identify bolt Reply to specific post Reply with quote
Try again!
BrianLivingstone
PostPosted: Wed Jan 10, 2018 9:40 am    Post subject: Re: Help to identify bolt Reply to specific post Reply with quote
46 Ford 2 n
Blue Jay
PostPosted: Wed Jan 10, 2018 10:13 am    Post subject: Re: Help to identify bolt Reply to specific post Reply with quote
Probably just an access point to a set screw, mine is just a 1/8" pipe plug. Your picture has me a little confused, looks like the right side of the tractor but clutch and brake are on the left side and 3 point quadrent on the right.
My tractor is a 46 also that Dad bought the year I was born.
JMOR
PostPosted: Wed Jan 10, 2018 10:30 am    Post subject: Re: Help to identify bolt Reply to specific post Reply with quote
looks about correct height for oil level check plug
Secret Squirrel
PostPosted: Wed Jan 10, 2018 10:34 am    Post subject: Re: Help to identify bolt Reply to specific post Reply with quote
It is a pilot bolt that holds a shaft in place, or at least is on mine.
BrianLivingstone
PostPosted: Wed Jan 10, 2018 10:48 am    Post subject: Re: Help to identify bolt Reply to specific post Reply with quote
It looks like a 1/4" smooth shaft that is 3 1/2 - 4" long . I was afraid that I may have unhooked something on the inside when I pulled it out.
JMOR
PostPosted: Wed Jan 10, 2018 11:03 am    Post subject: Re: Help to identify bolt Reply to specific post Reply with quote
Secret Squirrel nailed it......pins the reverse idler gear shaft.
R Geiger
PostPosted: Wed Jan 10, 2018 11:05 am    Post subject: Re: Help to identify bolt Reply to specific post Reply with quote
You may have gotten lucky, looks like it is pin for the reverse idler shaft. Parts books are great.
JMOR
PostPosted: Wed Jan 10, 2018 11:23 am    Post subject: Re: Help to identify bolt Reply to specific post Reply with quote
on second thought..........isn't that the wrong side for that?
HCooke
PostPosted: Wed Jan 10, 2018 2:19 pm    Post subject: Re: Help to identify bolt Reply to specific post Reply with quote
That picture is reversed!
BrianLivingstone
PostPosted: Wed Jan 10, 2018 3:12 pm    Post subject: Re: Help to identify bolt Reply to specific post Reply with quote
i apoligise for the photo. I knew it was off 90 degrees but I didn't realize I had it reversed.
Good eye
howdy1960
PostPosted: Thu Jan 11, 2018 8:14 am    Post subject: Re: Help to identify bolt Reply to specific post Reply with quote
You did want to rebuild the tranny this year didn't you?
Note to self: "DO 'NOT' REMOVE THIS BOLT!"
Maybe I should black marker it above the bolt as I 'know' I'll forget where I put the note lol
BrianLivingstone
PostPosted: Thu Jan 11, 2018 3:30 pm    Post subject: Re: Help to identify bolt Reply to specific post Reply with quote
Do you think I have a chance of doing damage to the tranny?
It seemed to go back into the same place and it drove fine last night.
