Case 188 engine rocker arm install
panningbros
PostPosted: Wed Jan 10, 2018 10:59 am    Post subject: Case 188 engine rocker arm install Reply to specific post Reply with quote
Is there a trick to installing the rocker arm assembly on a Case 188? Everything is loose and even 2 of us don't have enough hands to hold everything in place. Poor design
John Saeli
PostPosted: Wed Jan 10, 2018 11:39 am    Post subject: Re: Case 188 engine rocker arm install Reply to specific post Reply with quote
No trick. I'm not gifted in any sense, but even with my clumsy 2 hands, I've done it myself. Put it together on the bench, 1 hand on 1 end, 1 hand on the other & install.
Adirondack case guy
PostPosted: Wed Jan 10, 2018 4:33 pm    Post subject: Re: Case 188 engine rocker arm install Reply to specific post Reply with quote
Sometimes one guy with two hands is better than two guys and three hands. As John said, squeeze the entire assy. together and install over studs from front to back or back to front. Once pretty well down on studs, tilt the rockers to engage the pushrods and tighten evenly from front to back.
How did you make out installing the sleeves an pistons??? Saw a previous post you made about that.
Loren
casecollectorsc
PostPosted: Wed Jan 10, 2018 6:57 pm    Post subject: Re: Case 188 engine rocker arm install Reply to specific post Reply with quote
You're kidding, right?
olgentdc
PostPosted: Thu Jan 11, 2018 5:30 pm    Post subject: Re: Case 188 engine rocker arm install Reply to specific post Reply with quote
Mine always gets a thin wire holding it all together
