Ford 2110 Tractor problem
Mr. Hand
PostPosted: Thu Jan 11, 2018 8:28 am    Post subject: Ford 2110 Tractor problem Reply to specific post Reply with quote
I have a true problem with my Ford 2110 LCG tractor. the year it was made was 1967. I just recently changed all the oils and fluids on the tractor and ever since I did that I have had countless problems with the cooling system. Just the other day I started it up and it started to overheat really bad. I shut it off and let it cool down. when I got this tractor I replaced the thermostat with a new one and I also replaced some other cooling parts within the cooling system. but that was about 5 months ago. and the cooling system has had countless problems ever since I changed all the fluids about a week ago. I pulled it out of the garage yesterday and it started to overheat again so I shut it off. After a couple minutes I started it up again and it was cooled down a little bit.Then it starts spuing radiator fluid out the drain valve on the right side of the engine block. It hasn't stopped leaking out of that drain valve for a couple days now. and if you squeeze one of the radiator hoses it shoots out radiator fluid. Do I need to replace that drain valve? or what could be wrong with my cooling system?
old
PostPosted: Thu Jan 11, 2018 8:59 am    Post subject: Re: Ford 2110 Tractor problem Reply to specific post Reply with quote
So did you replace the coolant when you did the fluids?? If you did and used the block drain to drain it there may well be some dirt/rust in the valve now so it will not shut all the way off like it should,. Plus you also may now have a bad thermostat and or a clogged up cooling system which may need to be flushed
Mr. Hand
PostPosted: Thu Jan 11, 2018 10:00 am    Post subject: Re: Ford 2110 Tractor problem Reply to specific post Reply with quote
I didn't change the coolant. i didn't even touch the coolant system while i was working on the tractor.
old
PostPosted: Thu Jan 11, 2018 10:39 am    Post subject: Re: Ford 2110 Tractor problem Reply to specific post Reply with quote
In that case it maybe a good idea to drain the cooling system and flush it and maybe replace the thermostat
Mr. Hand
PostPosted: Thu Jan 11, 2018 10:42 am    Post subject: Re: Ford 2110 Tractor problem Reply to specific post Reply with quote
So drain everything and replace the thermostat again? how about that valve. could it be a possibility that that valve needs replaced?
old
PostPosted: Thu Jan 11, 2018 1:20 pm    Post subject: Re: Ford 2110 Tractor problem Reply to specific post Reply with quote
Yes the valve may need to be replace or at the very least pulled out and check to see why it leaks
Mr. Hand
PostPosted: Thu Jan 11, 2018 2:06 pm    Post subject: Re: Ford 2110 Tractor problem Reply to specific post Reply with quote
ok thanks alot
