Case 410
BrianV_
PostPosted: Thu Jan 11, 2018 8:52 am    Post subject: Case 410 Reply to specific post Reply with quote
A local-ish dealer has had a Case 410 listed for sale since the summer, and the price keeps dropping slowly. It's now at $2500 CAD. It looks in good condition, and is supposed to be in good running order.
A few questions I have about it:
Does anyone have any info about what loaders would fit this tractor?
How hard would it be to add power steering? I see where it is *supposed* to mount on the front of the block, so it it pretty much plug and play if I can locate the PS parts? Does anyone sell remanufactured PS pumps?
I've looked enough into using Eagle Hitch with Class I 3PH implements, which I have. It looks like I might need to weld a few pins slightly different on my implements, and potentially locate or fabricate a 'high' mount point for the center link. Is this more or less correct?
This seems like a lot of tractor for $2500CAD - I imagine most people are scared off by the Eagle Hitch. 3PH is king around here.
The local Case IH dealer is 5 minutes away, sandwiched between the John Deere and AGCO dealerships, so dealer support is easy.
How is parts availability for these?
[/list]
BrianV_
PostPosted: Thu Jan 11, 2018 8:53 am    Post subject: Re: Case 410 Reply to specific post Reply with quote
Oh, and how hard is it to locate a front-mount aux hydraulic pump for one of these?
Josh Hagan
PostPosted: Fri Jan 12, 2018 3:20 am    Post subject: Re: Case 410 Reply to specific post Reply with quote
As far as the power steering goes you would
need a different steering box steering pump
and the 410 had a hydraulic ram that
attached to the pitman arm. Might take some
effort to find all the parts
chuck machinist
PostPosted: Sat Jan 13, 2018 10:27 am    Post subject: Re: Case 410 Reply to specific post Reply with quote
Will these pics help you? daynee on the tractor talk took these pics a period back . Post on tractor talk using his handle .See if he has any insight
