Cut out points replacement
Richard from SE AZ
PostPosted: Thu Jan 11, 2018 5:35 pm    Post subject: Cut out points replacement Reply to specific post Reply with quote
Here or the pictures of the diode (bridge rectifier ) that I replaced the cutout points with. No dead battery issues since I did this a few years ago.
Royse
PostPosted: Thu Jan 11, 2018 7:45 pm    Post subject: Re: Cut out points replacement Reply to specific post Reply with quote
Looks like a neat job Richard.
I've not had problems with my cutouts like I did with my regulators.
But just in case I do, what were the part numbers of those diodes?
Richard from SE AZ
PostPosted: Thu Jan 11, 2018 9:09 pm    Post subject: Re: Cut out points replacement Reply to specific post Reply with quote
This is the number on the diode KBPC5010
Richard from SE AZ
PostPosted: Thu Jan 11, 2018 9:15 pm    Post subject: Re: Cut out points replacement Reply to specific post Reply with quote
They cost about one dollar or less. I ordered five for $.83 each. I have set up a couple of other owners tractors with these.
Royse
PostPosted: Fri Jan 12, 2018 4:50 am    Post subject: Re: Cut out points replacement Reply to specific post Reply with quote
Thank you!
howdy1960
PostPosted: Sat Jan 13, 2018 7:56 am    Post subject: Re: Cut out points replacement Reply to specific post Reply with quote
On recommendation of folks here I did same thing to mine and had zero issues till this winter.
Come spring I get to find out where the magic smoke escaped from.
Caryc
PostPosted: Sun Jan 14, 2018 4:45 pm    Post subject: Re: Cut out points replacement Reply to specific post Reply with quote
CVPost-Richard from SE AZ wrote:
(quoted from post at 22:15:57 01/11/1Cool They cost about one dollar or less. I ordered five for $.83 each. I have set up a couple of other owners tractors with these.
OK, I'm a little behind here, what are these cutout points to which you're referring?
R Geiger
PostPosted: Sun Jan 14, 2018 6:43 pm    Post subject: Re: Cut out points replacement Reply to specific post Reply with quote
Caryc wrote:
(quoted from post at 18:45:17 01/14/1Cool
Before Voltage regulators cutout relays (points) were used to disconnect the generator from the alltery when tractor was not running. Voltage regulators still have a cutout relay in them.
kleinerpiner
PostPosted: Tue Jan 16, 2018 9:28 am    Post subject: Re: Cut out points replacement Reply to specific post Reply with quote
This looks like a good solution for my 9N.
How may diodes are needed? You mentioned "bridge rectifier", which leads to think maybe more than one diode is needed for the bridge?
Are there voltage or current ratings on these?
And last, where did you order them from?
Thanks for sharing the tip!
souNdguy
PostPosted: Tue Jan 16, 2018 11:49 am    Post subject: Re: Cut out points replacement Reply to specific post Reply with quote
the bridge has 4 diode segments, you only need one of them... depending on what bridge you buy, it's easy to get 25a and 50a models. PIV of an anemic 50 or above will suffice.
