Steering Shaft Repair Kit (SRK632AA)
Goto page 1, 2  Next
rlneal6180
PostPosted: Fri Jan 12, 2018 6:38 am    Post subject: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
My Ford 2600 is leaking power steering fluid from under the steering wheel. The steering shaft is pitted just above the upper seal, causing fluid to pass through and exit the top of housing. I see that this is a problem with many different Ford models. So I ordered the Steering Shaft Repair Kit (SRK632AA) from Yesterday's Tractors only to find that the sleeve fits loosely on the shaft. No tapping required to move it into position at all. Has anyone experienced this problem?
Richard
View user's profile MSN Messenger
Royse
PostPosted: Sat Jan 13, 2018 5:54 am    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
I have not. You might want to call or write YT parts dept.
They may have an answer and are usually quite helpful.
rlneal6180
PostPosted: Sat Jan 13, 2018 2:26 pm    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
Thanks Royse, I've done just that, no word yet.
pig9r
PostPosted: Sat Jan 13, 2018 7:12 pm    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
This site won’t let me post the link and you don’t have private messaging enabled - but there is a very helpful tutorial for repairing the steering shaft on the 2600. If you google “steering shaft seal replacement ford 2600” it should pull up a detailed pdf file from another tractor site.
rlneal6180
PostPosted: Mon Jan 15, 2018 6:07 am    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
Hi pig9r, thanks for the reply. I downloaded that pdf file before I ordered the repair kit. I've followed the correct procedure. The problem is, the sleeve doesn't fit tightly. In fact it fits loose, very loose. Also, which setting do I change for private messaging? I couldn't find it in my profile settings.
rlneal6180
PostPosted: Mon Jan 15, 2018 6:18 am    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
I found where to enable messenger.
BobReeves
PostPosted: Mon Jan 15, 2018 5:03 pm    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
It's a Speedi-Sleeve, Return the kit, measure the shaft, order the proper sized Speedi-Sleeve and a new seal.
rlneal6180
PostPosted: Tue Jan 16, 2018 6:22 am    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
Hi Bob, I didn't realize when ordering that repair kit you had to specify the sleeve size, or did I order the wrong kit?
BobReeves
PostPosted: Tue Jan 16, 2018 9:48 am    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
No, believe only one universal kit available for Ford but you know what universal means.. Don't fit nutten right.
Speedi-Sleeve is the trade name for the shaft repair sleeve in the kit and they can be bought at most large auto supply stores or on-line in almost any size one might need.
rlneal6180
PostPosted: Tue Jan 16, 2018 12:20 pm    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
Bob, I've found the Speedi-Sleeve info. Once I have an accurate measurement of the steering shaft OD, I'll order one. I've considered replacing the entire shaft but will take more time and money. LOL
Thanks again.
BobReeves
PostPosted: Tue Jan 16, 2018 1:28 pm    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
They can be used to repair almost any shaft that has a rubber seal, used two on the brake cross shaft to fix a leak on my 3600.
After the sleeve is installed the aluminum installation tool supplied makes a great mold for a lead hammer.
rlneal6180
PostPosted: Tue Jan 16, 2018 3:02 pm    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
Bob, what am I looking at, a Speedi-Sleeve?
I got a measurement......shafts OD. = 22.18mm sleeve I'D =22.07mm. The sleeve is from the repair kit.
BobReeves
PostPosted: Tue Jan 16, 2018 3:36 pm    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
You are looking at what I did with the aluminum installation tool that comes with all Speedi-sleeves, just threw it in in case you or someone else wanted to repurpose the aluminum..
From your measurements the sleeve you have should work, shaft is 0.11 mm larger than the ID of the sleeve?
Sean in PA
PostPosted: Wed Jan 17, 2018 5:38 am    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
rlneal6180 wrote:
(quoted from post at 19:02:06 01/16/1Cool
Is the sleeve ID from what you measured, or just what the package says? If those are both true measurements, then I don't see how the sleeve could be loose on the shaft.
rlneal6180
PostPosted: Wed Jan 17, 2018 6:41 am    Post subject: Re: Steering Shaft Repair Kit (SRK632AA) Reply to specific post Reply with quote
Hi Sean, the measurement is from the sleeve. The kit doesn't give the sleeve's size. Regardless of my measurement, the sleeve slides up and down the shaft with ease.
Goto page 1, 2  Next
Page 1 of 2
