value of Behlen power steering
Clint Skarovsky
PostPosted: Fri Jan 12, 2018 8:01 am    Post subject: value of Behlen power steering Reply to specific post Reply with quote
We're parting out a 450 with power steering...any value to the unit? It's complete but wasn't working. As we've pulled it apart it seems like it had almost no fluid in it. If anyone is interested please feel free to contact me. Thanks
pete 23
PostPosted: Fri Jan 12, 2018 10:48 am    Post subject: Re: value of Behlen power steering Reply to specific post Reply with quote
I don't know what it is worth but am pretty sure someone will want it. Be sure to pull all components that go with it. That will include the flow divider regulator valve assembly, inside hydraulic valve with pipe connecting valve to flow divider , and the plug that is installed in the bracket hydraulic valves mount to .
Clint Skarovsky
PostPosted: Fri Jan 12, 2018 12:45 pm    Post subject: Re: value of Behlen power steering Reply to specific post Reply with quote
Exactly, it's complete so I want to keep everything needed. I'd like for it to find a new home. Thanks
Bob 7337
PostPosted: Fri Jan 12, 2018 3:07 pm    Post subject: Re: value of Behlen power steering Reply to specific post Reply with quote
Just wondered what power steering was worth too. Is it worth taking off tractor or just junking it with tractor
Thanks,
D Slater
PostPosted: Fri Jan 12, 2018 3:20 pm    Post subject: Re: value of Behlen power steering Reply to specific post Reply with quote
Value has a lot to do if it's guaranteed to be okay and work or sold as is. They are old and some no longer work or leak. May just be the priority parts bad but any repairs can add up or more than double price sold for you never know.
dgoodman2
PostPosted: Fri Jan 12, 2018 3:35 pm    Post subject: Re: value of Behlen power steering Reply to specific post Reply with quote
If one of these guys on here verify for me that will fit a Super M. I think it will. Then I'm interested in it. Give me your email.
hillbillyhim
PostPosted: Fri Jan 12, 2018 3:37 pm    Post subject: Re: value of Behlen power steering Reply to specific post Reply with quote
Watched steering shaft unit sell for $55 at an auction a couple weeks ago.
gene bender
PostPosted: Fri Jan 12, 2018 3:42 pm    Post subject: Re: value of Behlen power steering Reply to specific post Reply with quote
those will fit on any tractor that has a steering shaft to mount it on
Clint Skarovsky
PostPosted: Fri Jan 12, 2018 4:02 pm    Post subject: Re: value of Behlen power steering Reply to specific post Reply with quote
You can email me at Ctskarovsky@sbcglobal.net...text at 830-708-8167. Thanks
D Slater
PostPosted: Fri Jan 12, 2018 5:52 pm    Post subject: Re: value of Behlen power steering Reply to specific post Reply with quote
450 unit mounted under hood. More room under hoods on a 450. Hood would need heavy modification to clear. Hydraulic system to power unit on a 450 doesn't work on a SM. Steering unit will mount in front of rear steering post over the fuel tank by coupling the shafts but you will need to supply the pressure to run the steering unit. Look a few pages back at Charlie U post about mounting bracket for the behlen unit. Has a few pictures to give a idea what things would need. Lots of behlen units mounted at steering post had a one piece shaft going in that was made for mounting the steering wheel. 450 one has plain 7/8 shafts in and out with keyways. Rear shaft is longer than front one.
