53 axle replacement
Doug Thomas
PostPosted: Fri Jan 12, 2018 11:39 am    Post subject: 53 axle replacement Reply to specific post Reply with quote
we pulled the right side axle apart on my 53 NAA, splines are shot, hub is shot and the shims where in pieces. The axle nut was just a nut, no spring no slot and no key. the axle has no slot for a key or spring. is it possible they have been replaced once before?
ZANE
PostPosted: Fri Jan 12, 2018 2:14 pm    Post subject: Re: 53 axle replacement Reply to specific post Reply with quote
China, the land of almost right!
Zane
Dean
PostPosted: Fri Jan 12, 2018 2:52 pm    Post subject: Re: 53 axle replacement Reply to specific post Reply with quote
It is, of course, possible, but more than likely, it is just worn out.
Dean
Hobo,NC
PostPosted: Fri Jan 12, 2018 3:58 pm    Post subject: Re: 53 axle replacement Reply to specific post Reply with quote
Good Pix when you get a new axle post a pix of it to go with this post.. I have seen the axle turned down and re-threaded...
Doug Thomas
PostPosted: Fri Jan 12, 2018 6:14 pm    Post subject: Re: 53 axle replacement Reply to specific post Reply with quote
It is worn out. My question was why is it different than it should be. It doesn't really matter because I have to replace it I was just curious if anyone else has seen an axle like this.
Doug Thomas
PostPosted: Fri Jan 12, 2018 6:16 pm    Post subject: Re: 53 axle replacement Reply to specific post Reply with quote
I will, we are going to pull the left side apart as well to see what kind of shape that one is in also.
Royse
PostPosted: Fri Jan 12, 2018 6:53 pm    Post subject: Re: 53 axle replacement Reply to specific post Reply with quote
What part of the world are you located in? I have an axle
here in central Michigan you could compare it to if you're close.
Doug Thomas
PostPosted: Fri Jan 12, 2018 7:10 pm    Post subject: Re: 53 axle replacement Reply to specific post Reply with quote
I'm on the east coast
Kirk-NJ
PostPosted: Sat Jan 13, 2018 3:16 am    Post subject: Re: 53 axle replacement Reply to specific post Reply with quote
East coast is long. I might have one in NJ if you are near there.
Kirk
Kirk-NJ
PostPosted: Sat Jan 13, 2018 7:31 am    Post subject: Re: 53 axle replacement Reply to specific post Reply with quote
Also have the back half of an NAA. Bolt up and go. Located in NJ
07838
Doug Thomas
PostPosted: Sat Jan 13, 2018 9:27 am    Post subject: Re: 53 axle replacement Reply to specific post Reply with quote
In Connecticut.
Doug Thomas
PostPosted: Sat Jan 13, 2018 6:52 pm    Post subject: Re: 53 axle replacement Reply to specific post Reply with quote
What would the sale price be on that NAA back half
Kirk-NJ
PostPosted: Sun Jan 14, 2018 4:03 am    Post subject: Re: 53 axle replacement Reply to specific post Reply with quote
$300 top cover and PTO shaft included.
Email is open in classic view
