More Horsepower
Farmallpuller03
PostPosted: Fri Jan 12, 2018 4:15 pm    Post subject: More Horsepower Reply to specific post Reply with quote
I need a little help... I'm pulling a 1941 Farmall M, I have a turbo on it and i was wondering if there is anything else i could do to get more horsepower?[/b]
IHTimmy
PostPosted: Fri Jan 12, 2018 4:55 pm    Post subject: Re: More Horsepower Reply to specific post Reply with quote
The old boy I started to work with in 76 his name Willy he
show me make a m and sm and 400 and 450 run we install
m&w pistons and liners lp Head he drill Governors weights
with 3/8 drill Bit new gov spring on the carb he would used a
806 venture and main Jet take the muffler and knock the
baffles out of muffler or a straight pipe we did things to 460
and 560?s same on 656?s
David G
PostPosted: Fri Jan 12, 2018 5:04 pm    Post subject: Re: More Horsepower Reply to specific post Reply with quote
Nitrous Oxide, hold onto your hat.
mattwillson
PostPosted: Sat Jan 13, 2018 3:32 am    Post subject: Re: More Horsepower Reply to specific post Reply with quote
LP head , adjust waste gate to 15psi boost, 100 octane gas. Only issue would be traction.
Dave S.
PostPosted: Sun Jan 14, 2018 9:25 am    Post subject: Re: More Horsepower Reply to specific post Reply with quote
With a turbo I think it would make more HP using the low compression distilate head and pistons. Leaves more volume for fuel mixture and compression pressure would still be good.
View user's profile AIM Address
JAsher452x
PostPosted: Mon Jan 15, 2018 11:35 am    Post subject: Re: More Horsepower Reply to specific post Reply with quote
it all comes down to how much you want to spend and what are the limits to the rules. since you already have a turbo, I would build an intercooler. a small intercooler and an ice box with a 12v pump to circulate the chilled water.
Another option is to change fuel. I know I will catch some grief for this but, get another carb and build it to run E85. It has an octane rating of 105-110. it will drink about twice as much fuel, but you can throw a lot more boost at it and will lower your EGT on your turbo.
Just my two cents for more power with what you already have
High Octane
PostPosted: Wed Jan 17, 2018 10:18 pm    Post subject: Re: More Horsepower Reply to specific post Reply with quote
Convert it to alcohol. Dial in your ign.
kossuth
PostPosted: Fri Jan 19, 2018 1:17 am    Post subject: Re: More Horsepower Reply to specific post Reply with quote
There is alot you could do. Areas where power can be made.
1. Convert the entire valvetrain to roller
2. Custom grind a cam for the motor
3. Fuel inject the motor and work on injector placement onto the back of the intake valve.
4. Port and polish the head
5. Lighten the rotating assembly
6. Intercool your existing turbo setup
There is alot you can do, just depends on how deep your wallet it.
