Massey 44 starter
NeilY
PostPosted: Fri Jan 12, 2018 10:49 pm    Post subject: Massey 44 starter Reply to specific post Reply with quote
Will a starter off a Massey 444 work on a 1950 Massey 44?
Dieseltech
PostPosted: Sat Jan 13, 2018 2:10 am    Post subject: Re: Massey 44 starter Reply to specific post Reply with quote
Believe it will bolt on, and it's 12 volt if I recall.
David G
PostPosted: Sat Jan 13, 2018 6:05 am    Post subject: Re: Massey 44 starter Reply to specific post Reply with quote
I would believe it should fit if 44 is 4 cylinder and not 6, do not know about 6.
centash
PostPosted: Sat Jan 13, 2018 6:11 am    Post subject: Re: Massey 44 starter Reply to specific post Reply with quote
444 is 12 volt, 44 is 6 volt. If converting to 12 volt, you will need new lights, generator, regulator, etc. Ben
NeilY
PostPosted: Sat Jan 13, 2018 6:21 am    Post subject: Re: Massey 44 starter Reply to specific post Reply with quote
My Tractor has already Ben converted to 12 volt
David G
PostPosted: Sat Jan 13, 2018 6:41 am    Post subject: Re: Massey 44 starter Reply to specific post Reply with quote
I put a gear reduction starter on my MH44 EFI from Goldburg, the compression is 9.5:1, it cranks over a lot easier.
krm
PostPosted: Sat Jan 13, 2018 7:45 am    Post subject: Re: Massey 44 starter Reply to specific post Reply with quote
Starter for a Cockshutt 40 or 50 is the same as a MH 44 except for where the battery cable mounts.
NeilY
PostPosted: Sat Jan 13, 2018 8:04 am    Post subject: Re: Massey 44 starter Reply to specific post Reply with quote
Will it work? The nose cone on my original starter looks
Just a little longer than the starter off the 444
Starter?
buickanddeere
PostPosted: Sat Jan 13, 2018 9:26 am    Post subject: Re: Massey 44 starter Reply to specific post Reply with quote
Starters are as generic as socks . Just look at the number of mounting bolts , pattern, gear tooth number , tooth pitch and rotation. New Generic starters from eBay of your local parts shop son’t Cost any more than a pre abused starter . There are some outright powerful starters such as the MT39 which will wail over even an 8.1 Diesel in the winter .
NeilY
PostPosted: Sat Jan 13, 2018 9:42 am    Post subject: Re: Massey 44 starter Reply to specific post Reply with quote
Thank you buickanddeere, can you send more info
On that powerfull starter you mentioned as I am
Rebuilding my h260 and have a set of M&W pistons
I?m putting in. Compression ratio will be higher.
buickanddeere
PostPosted: Sat Jan 13, 2018 11:58 am    Post subject: Re: Massey 44 starter Reply to specific post Reply with quote
Took almost a minute to google MT39 and find the info.
http://www.delcoremy.com/getmedia/a6f943ce-00ac-40b3-8725-7324cee819a1/Delco-39MT-Single-Page-Brochure-1-16.pdf.aspx
http://www.delcoremy.com/Starters/Find-by-Model-Family/39MT-Gear-Reduction-Starter#features
David G
PostPosted: Sat Jan 13, 2018 12:46 pm    Post subject: Re: Massey 44 starter Reply to specific post Reply with quote
Go to Goldburg's site.
