Hey Welders---Warpage?
Goto page 1, 2  Next
big tee
PostPosted: Sat Jan 13, 2018 9:12 am    Post subject: Hey Welders---Warpage? Reply to specific post Reply with quote
I am building a vertical tillage tool and am putting a rolling harrow on the back for firming and smoothing. I am cheap so I took some used soil saver coulters and cut out my support discs with the plasma cutter and now I want to weld them to the axle. Question is how do I keep the shaft from warping. If I weld one side -say 1/4 of the way around and then went to the other side-180 degrees- and weld 1/4 of the way around and then let them cool and come back and finish welding would that help. It seems like everything I weld no matter how much I clamp it warps a little. The pictures of the completed baskets are a store bought ones. This is tractor related for we are going to pull it with a Deere!-Thanks---Tee
David G
PostPosted: Sat Jan 13, 2018 9:15 am    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
That is cool.
JD Seller
PostPosted: Sat Jan 13, 2018 9:19 am    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
You need to keep all the welds in line/across from each other on each disk. How your trying to weld them quickly across form each other is the only way to try and make them as straight as possible. Then when your done welding the disks to the center axle you will have to straighten the shaft with a jack/press. I saw these being made in the JD plant and they had to straighten them before the outer bars where installed.
Roger in Iowa
PostPosted: Sat Jan 13, 2018 9:29 am    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
The second version of the Deere doesn't even have a central axle all the way thru.
jon f mn
PostPosted: Sat Jan 13, 2018 9:30 am    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
Keeping them perfect is very difficult. You can straighten then in a press if you have one and can get the assy in it. You can also support the shaft and give it a whack with a mall. But the method I would use is heat. You find the long side and heat that til it just shows red then cool it. You can let them air cool or use water. You can google heat straightening, they have some excellent videos on straightening bridge beams. I would think getting anything to weld to discs without cracking off will be your biggest challenge, depending on the discs.
View user's profile AIM Address
504
PostPosted: Sat Jan 13, 2018 10:18 am    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
They are made without the center axle,they have a self centering bearing on each end. If they are not perfectly straight it makes no deference to the running of the basket. I do not know if they have pictures but you can look them up at Yetter.com, they build them, using their name and for JD.
ss55
PostPosted: Sat Jan 13, 2018 10:23 am    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
The outer cage will contribute much more strength than the center axle. Once everything is welded together, the full length axle adds some weight but not much extra strength. Would two or four tack welds on each plate be enough to hold them in place during fabrication without warping the axle? Maybe tack weld two of the cage bars in place to establish the proper twist across all the plates before tacking the axle?
What material are you using for the cage bars? The coulters were probably high carbon steel and hardened for good wear (0.7 to 1.00 percent carbon, maybe 1080 steel or better?). Will that cause any problems with welds cracking at the cage bars?
jon f mn
PostPosted: Sat Jan 13, 2018 10:30 am    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
Yes cracking at the welds will be an issue with those blades, how much will depend on the blade. Some weld better than others. Can't say I've ever seen them used in a structural situation before. Several people have tried to use them for stands and such with mixed results.
David G
PostPosted: Sat Jan 13, 2018 10:34 am    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
Would mild steel not crack?
jon f mn
PostPosted: Sat Jan 13, 2018 10:45 am    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
Discs are very brittle to start with, when you weld them it gets worse. If you have seen a broken disc they most always snap clean with no tearing. Mild steel when broken is usually deformed some from stretching, it's that flexibility that makes it work in structural situations. It's about alloys and what works best in each situation. The very thing that makes blades hold up for their purpose makes them a poor choice for structural uses.
big tee
PostPosted: Sat Jan 13, 2018 11:51 am    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
Like I said-I am cheap. I am using 3/4 in re-bar for my cage. Menards has a 11% discount + 2% big card discount and they start out at $13 apiece for 20 footers. A lot cheaper than cold rolled. Right now I have my center disc welded in and this is my reference point to set the end ones 1/2 a notch off to set my spiral. Some manufactures use 3/4,some use 1 inch and some use pipe. Will keep you all informed-THANKS for the replies-all off you.---Tee
ss55
PostPosted: Sat Jan 13, 2018 12:46 pm    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
An OEM (Original Equipment Manufacturer) would probably use 1020 HRS for the plates for low cost, durability and ease of welding.
A couple of things to note are it looks like the OEM uses wider plates than the coulters (I'll guess 1/2 or 3/4 inch thick plates vrs 3/16 or 1/4 inch thick for the coulters) and the OEM put notches in the plates that wrap about half way around the cage rods. With the notches, the cage rods can be welded to the perimeter of the plates with two welds across the width of the plates and those welds can all be made from outside of the cage.
I'm not sure what material an OEM would use for the cage rods, probably 5/8 or 3/4 inch diameter 1020 HRS or maybe 1018 CRS for a little more strength and wear resistance. I think re-bar would be too soft and would easily bend.
Maybe someone with this type of rollers can help out the OP by measuring one that works well and has held up well.
ss55
PostPosted: Sat Jan 13, 2018 12:52 pm    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
Re-bar will probably work if the span between plates is not too large.
RBoots
PostPosted: Sat Jan 13, 2018 1:29 pm    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
Tee, usually if you heat hardened steel like you have in those discs, it will weld better. You probably don't have to be too precise, and I've been out of the welding part of my life for a ehile except my own things, but it seems as if it was 330? or maybe 430? degrees that took the temper and such out of hardended steel. Not saying it won't crack around the edges where you heat it, but the weld should hang on better
jeffcat
PostPosted: Sat Jan 13, 2018 1:52 pm    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
May I add a little insight. If you need to heat those disks, and want to make it a nice and wide path of even heat try using this. This weed burner will give an unbeleavable amount of heat and you just swirl it around. Straighten out several bent items. Spend the couple of extra bucks for the one with the piezo ignition. Very handy. Very nice tool but watch your control. Things get really hot very fast!
Goto page 1, 2  Next
Page 1 of 2
