Hey Welders---Warpage?
Goto page Previous  1, 2
carvel minne farmer
PostPosted: Sat Jan 13, 2018 3:23 pm    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
good evening big tee, nice job you've done so far on the cutting and fitting, the method I would use to keep everything straight is what I call stich and go, by that I mean you lay each roller out like you have it, tack weld (no more than a 1/4" long tack), keep your heat input on the metal shaft and plates to a minimum. about 3 tacks on each side of each disc plate, tack the 2 end pieces the same, with all the plates in place lay your cross bars at the angle you want, tack them into place, again small tacks, moving from end to end don't work in one area long move from 1 end to the other back to the middle keep it moving don't let any area get hot, it takes more time but saves you a lot of time and headaches trying to straighten heat warped plates and shafts. the key big tee is paitience and keep moving, if you have 2 or three units laid out move from one to the other again keeping the amount of time and heat input to each weld to a minimum.
4520BW
PostPosted: Sat Jan 13, 2018 5:32 pm    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
What are you using to build the tool on? I was wondeing if it will be heavy enough. My turbo till is so heavy it dogs the 5095 pulling it down the road. A few years back my neighbor bent a bar on his basket so I cut out the bad spot,maybe 16 inches, and welded in a new bar. The only rod I has was stainless and a 1/4 inch bigger. If you look across the field while it's running you can see the shinny bar.
big tee
PostPosted: Sat Jan 13, 2018 5:46 pm    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
Hi 4520--2 of these, Glencoe 13 shank SS.---Tee
4520BW
PostPosted: Sat Jan 13, 2018 6:35 pm    Post subject: Re: Hey Welders---Warpage? Reply to specific post Reply with quote
So how wide you making it?
Page 2 of 2
