Hey Old
Goto page 1, 2  Next
rohdog50
PostPosted: Sat Jan 13, 2018 9:41 am    Post subject: Hey Old Reply to specific post Reply with quote
Rich,
I was plowing snow this morning with our 1966 MF-135 (Continental Z-145 gas)and for some reason,i had to pull the choke 1/4" out to keep it running for 3 hrs,i've never had to do this ever....what gives? I just filled it with 93 octane and a can of seafoam...it was 8 degrees when I started it...I know it's not the cold...it's ran like a top in - 10-15 temps plenty of times.
Anyway I figured you might point me in the right direction. Thanks
Keith
old
PostPosted: Sat Jan 13, 2018 9:52 am    Post subject: Re: Hey Old Reply to specific post Reply with quote
Try opening up the main jet adjustment 1 or so turns out. When it is cold engines seem to like bit more gas to run well
jon f mn
PostPosted: Sat Jan 13, 2018 9:59 am    Post subject: Re: Hey Old Reply to specific post Reply with quote
Likely the 93 octane is just burning too cold for that temp. The higher the octane the cooler it runs and the less power it will produce. Your engine is likely just trying to compensate for the cooler burning fuel. You should be using regular gas. That is unless you have modified your engine with higher compression, timing, and/or cam work.
View user's profile AIM Address
David G
PostPosted: Sat Jan 13, 2018 10:01 am    Post subject: Re: Hey Old Reply to specific post Reply with quote
Why would you put 93 octane in it?
rohdog50
PostPosted: Sat Jan 13, 2018 10:03 am    Post subject: Re: Hey Old Reply to specific post Reply with quote
Rich,
I'll go out in a little bit and see if that helps. Thanks again!
Keith
rohdog50
PostPosted: Sat Jan 13, 2018 10:04 am    Post subject: Re: Hey Old Reply to specific post Reply with quote
Because it don't like 87
rohdog50
PostPosted: Sat Jan 13, 2018 10:11 am    Post subject: Re: Hey Old Reply to specific post Reply with quote
Jon,
Back in 1966,when this tractor was built....regular leaded fuel was 93 octane,99 octane for premium and 102 octane for high or super premium. This tractor does not run well on 87 octane fuel.....trust me....lol
old
PostPosted: Sat Jan 13, 2018 10:13 am    Post subject: Re: Hey Old Reply to specific post Reply with quote
By the way the higher octane stuff is not needed and will also cause you problems like your having. So again that leads me to having it running a bit to lean and choking it makes it run richer
rohdog50
PostPosted: Sat Jan 13, 2018 10:25 am    Post subject: Re: Hey Old Reply to specific post Reply with quote
Rich,
I can see I'm not gonna win the octane battle...lol But anyway, I have used 93 octane in this tractor for many years now and never had a problem....maybe that 16 oz of seafoam to 10 gallon fuel was too much?
David G
PostPosted: Sat Jan 13, 2018 10:28 am    Post subject: Re: Hey Old Reply to specific post Reply with quote
So no science behind it.
Steve@Advance
PostPosted: Sat Jan 13, 2018 11:23 am    Post subject: Re: Hey Old Reply to specific post Reply with quote
The Seafoam could have contributed. It is a flammable petroleum product, and about 25% isopropanol alcohol.
Not sure what the BTU rating of the petroleum blend is, but the alcohol is much lower than gasoline.
So, the combination of diluting the fuel with Seafoam, the ethanol already in the gas, and the cold air, (which is denser and requires more fuel to get the ratio right),and a possibility the main jet may have picked up some trash or deposits, can easily add up to the mixture needing to be adjusted.
How is the engine temperature? Thermostat may be leaking by, doesn't take much when it's that cold.
old
PostPosted: Sat Jan 13, 2018 12:41 pm    Post subject: Re: Hey Old Reply to specific post Reply with quote
About the only advantage I could see you from the 93 octane is the fact it may not have alcohol in it. Ya to run the cheaper stuff you do need a hotter plug
Russ from MN
PostPosted: Sat Jan 13, 2018 1:22 pm    Post subject: Re: Hey Old Reply to specific post Reply with quote
I think you need to adjust the carburetor a little, if that doesn't do it then it needs cleaning. According to tactordata that engine is only 7.1:1 compression ratio, there is no way it need high octane gas.
rohdog50
PostPosted: Sat Jan 13, 2018 1:41 pm    Post subject: Re: Hey Old Reply to specific post Reply with quote
Rich,
Well you were right...I turned the main jet screw open about 3/4 turn after engine was warm...increased throttle to 1500 rpm,i stopped turning when I could hear engine smooth out,then went out and plowed for 30 minutes and with no choke it's running good again. Thank you Old and everyone for your help.
Keith
old
PostPosted: Sat Jan 13, 2018 3:03 pm    Post subject: Re: Hey Old Reply to specific post Reply with quote
Winter and cold temps call for more fuel. The tractor I run this time of year get the carb adjusted on them twice YEAR SOME Time more due to the weather
Goto page 1, 2  Next
Page 1 of 2
