Hey Old
Goto page Previous  1, 2
JD Seller
PostPosted: Sat Jan 13, 2018 4:51 pm    Post subject: Re: Hey Old Reply to specific post Reply with quote
rohdog50: The reason your need to run with the choke out is the colder air is more dense. So your able to get more oxygen into the motor in colder temperatures. Thus you need more fuel in to make the mixer not be lean. This is a major issue with tractor pullers. Air temperatures effect the amount of fuel or water you inject into the tractor to have maximum HP/RPM. Go to a tractor pull that is later in the fall and watch some of the fellows having trouble getting off the line. Their tractors are too lean to get the fire going like they are used too in hot weather.
I am not sure but if I remember correctly some of the older airplanes were set up to where you could adjust the mixer while in flight. They had the air density problem due to altitude and temperature.
As for running the better fuel. I can tell you the majority of the gas tractors and small motors around this part of North-Eastern Iowa will not run very well on the lower octane, ethanol added, 87 fuel. It must be regional as many fellow say theirs runs like it was new again on the lower grades of gas.
Hoenes
PostPosted: Sat Jan 13, 2018 5:48 pm    Post subject: Re: Hey Old Reply to specific post Reply with quote
Agreed. I got some blue "jet A" from a friend one time , and ran it in my WD. Man it ran good. Got a little warm though.
rohdog50
PostPosted: Sat Jan 13, 2018 6:11 pm    Post subject: Re: Hey Old Reply to specific post Reply with quote
JD Seller,
This tractor is 52 years old,i really don't use it that much....maybe 40 hrs a year the 87 octane fuel here(northern ohio)goes bad in 2-3 months,which is another reason I run 93 octane fuel and seafoam as a fuel stabilizer.I have other newer gas equipment that runs fine on 87 (2 cub cadet riding mowers,pressure washers,generators,airless paint sprayers,1-ton truck....etc) But again they may sit for months without use....and for that reason and my piece of mind,all my gas equipment gets 93 octane with seafoam mixed in. I have done this for well over 10 years now and have had 0 problems with fuel going bad and carburetors being pluged up.I just sold our old 1974 ford F700 farm truck last year,it had the 361 HD motor....it ran like crap too on 87 fuel so we had to run 93 octane in that one too.....like I said before,on these older gas motors,they were made to run on 93. Our fuel here isn't the greatest.......lol
old
PostPosted: Sat Jan 13, 2018 7:47 pm    Post subject: Re: Hey Old Reply to specific post Reply with quote
One of the reason the 87 octane gas goes bad is because of the alcohol in it that absorbs water and then evaporates and leave the water behind. The higher octane gas does not have the alcohol or is less likely to so it stays good longer
rohdog50
PostPosted: Sat Jan 13, 2018 8:01 pm    Post subject: Re: Hey Old Reply to specific post Reply with quote
Yes you are right
Page 2 of 2
