Adjusting Cub Cadet Snowthrower
Josh M.
PostPosted: Sat Jan 13, 2018 10:18 am    Post subject: Adjusting Cub Cadet Snowthrower Reply to specific post Reply with quote
I need to adjust a Cub Cadet QA42A to fit my narrow frame
Cub Cadet 125, it is set up for a wide frame. What are all of
the things I need to move to set it up for a narrow frame Cub?
Traper
PostPosted: Sat Jan 13, 2018 10:57 am    Post subject: Re: Adjusting Cub Cadet Snowthrower Reply to specific post Reply with quote
josh the easy way is to cut side rails just below frame narrow by welding a 1x1 angel iron at correct width.Any other way is a pain traper
DoubleO7
PostPosted: Tue Jan 16, 2018 7:47 pm    Post subject: Re: Adjusting Cub Cadet Snowthrower Reply to specific post Reply with quote
CVPost-traper wrote:
(quoted from post at 14:57:34 01/13/1Cool josh the easy way is to cut side rails just below frame narrow by welding a 1x1 angel iron at correct width.Any other way is a pain traper
There is no need to cut anything nor weld anything or add anything.
When you see it you will be able to see how it can be adjusted to fit either a WF or NF Cub Cadet.
R Bedell
PostPosted: Wed Jan 17, 2018 3:57 am    Post subject: Re: Adjusting Cub Cadet Snowthrower Reply to specific post Reply with quote
Josh M:
There is NO need to cut, weld, or add anything.
Go here, and download the Operator's Manual.... http://www.ccmanuals.info/throwers.html
You will the QA42A on Left hand side at the bottom.
